주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Asus ROG Strix GL702VS Trackpad Replacement
필요한 것
  1. Asus ROG Strix GL702VS Trackpad Replacement, Back Cover: 1 단계, 이미지 1개 중 1개
    • Flip the computer so the bottom of the laptop is facing up.
    댓글 쓰기
  2. Asus ROG Strix GL702VS Trackpad Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the ten JIS #0 screws around the edge of the laptop.
    • The two bottom screws are slightly shorter
    댓글 쓰기
  3. Asus ROG Strix GL702VS Trackpad Replacement: 3 단계, 이미지 2개 중 1개 Asus ROG Strix GL702VS Trackpad Replacement: 3 단계, 이미지 2개 중 2개
    • Use a Jimmy to carefully free each side of the bottom casing.
    댓글 쓰기
  4. Asus ROG Strix GL702VS Trackpad Replacement: 4 단계, 이미지 1개 중 1개
    • Lift up the back casing from the computer.
    • You may hear clicking or snapping sounds. This is just the plastic clips coming loose.
    댓글 쓰기
  5. Asus ROG Strix GL702VS Trackpad Replacement, Trackpad: 5 단계, 이미지 3개 중 1개 Asus ROG Strix GL702VS Trackpad Replacement, Trackpad: 5 단계, 이미지 3개 중 2개 Asus ROG Strix GL702VS Trackpad Replacement, Trackpad: 5 단계, 이미지 3개 중 3개
    • Disconnect the ribbon cables from the connectors at the bottom of the motherboard by lifting up the tabs with a nylon spudger tool.
    • Slide the ribbon cables out of the connectors on the motherboard.
    댓글 쓰기
  6. Asus ROG Strix GL702VS Trackpad Replacement: 6 단계, 이미지 2개 중 1개 Asus ROG Strix GL702VS Trackpad Replacement: 6 단계, 이미지 2개 중 2개
    • Remove the covering foil holding the trackpad into place.
    • Completely peel the foil back to ensure it does not interfere with the following processes.
    댓글 쓰기
  7. Asus ROG Strix GL702VS Trackpad Replacement: 7 단계, 이미지 2개 중 1개 Asus ROG Strix GL702VS Trackpad Replacement: 7 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Lift up speaker cable that is laying overtop using a pair of tweezers.
    • Do not to overextend the wire since you may accidently pull the wire out.
    댓글 쓰기
  8. Asus ROG Strix GL702VS Trackpad Replacement: 8 단계, 이미지 3개 중 1개 Asus ROG Strix GL702VS Trackpad Replacement: 8 단계, 이미지 3개 중 2개 Asus ROG Strix GL702VS Trackpad Replacement: 8 단계, 이미지 3개 중 3개
    • Remove the three 4mm JIS #0 screws that are securing the trackpad.
    댓글 쓰기
  9. Asus ROG Strix GL702VS Trackpad Replacement: 9 단계, 이미지 2개 중 1개 Asus ROG Strix GL702VS Trackpad Replacement: 9 단계, 이미지 2개 중 2개
    • Once freed, slide the trackpad backwards towards the center of laptop.
    • This may require some jiggling. Lifting the laptop off your working surface may help.
    • Sliding the trackpad back in can be a bit tricky. Ensure it is fully seated before continuing reassembly.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
5다른 기여자 명과 함께
Conor H Allen
회원 가입일: 09/16/19
640 평판
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 7
지난 30일: 32
전체 시간: 1,361
