주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Asus Transformer Book T100TAF Keyboard Replacement
필요한 것
    1. Asus Transformer Book T100TAF Keyboard Replacement, Keyboard: 1 단계, 이미지 1개 중 1개
      • Detach the keyboard from the screen by depressing the silver button on the hinge and pulling upwards on the tablet.
      댓글 쓰기
    2. Asus Transformer Book T100TAF Keyboard Replacement: 2 단계, 이미지 2개 중 1개 Asus Transformer Book T100TAF Keyboard Replacement: 2 단계, 이미지 2개 중 2개
      • Use a Phillips #00 screwdriver to remove the six 4 mm screws on the underside of the device.
      댓글 쓰기
    3. Asus Transformer Book T100TAF Keyboard Replacement: 3 단계, 이미지 2개 중 1개 Asus Transformer Book T100TAF Keyboard Replacement: 3 단계, 이미지 2개 중 2개
      • Use a metal spudger to pry up the rubber pads covering the two upper silver screws.
      • Use a Phillips #00 screwdriver to remove the two 5.5 mm screws under the rubber pads.
      댓글 쓰기
    4. Asus Transformer Book T100TAF Keyboard Replacement: 4 단계, 이미지 3개 중 1개 Asus Transformer Book T100TAF Keyboard Replacement: 4 단계, 이미지 3개 중 2개 Asus Transformer Book T100TAF Keyboard Replacement: 4 단계, 이미지 3개 중 3개
      • Remove the back cover.
      • Use a Phillips #00 screwdriver to remove all the screws from the metal, inside panel, including four black 4.0 mm screws along the top.
      • Remove four black 3.0 screws along the bottom.
      • Remove the one silver 5.0 mm screw in the top right corner.
      댓글 쓰기
    5. Asus Transformer Book T100TAF Keyboard Replacement: 5 단계, 이미지 1개 중 1개
      • Remove the metal keyboard cover from the device.
      댓글 쓰기
    6. Asus Transformer Book T100TAF Keyboard Replacement: 6 단계, 이미지 1개 중 1개
      • Use the Phillips #00 screwdriver to remove the 4.5 mm screw on the keyboard circuit board.
      댓글 쓰기
    7. Asus Transformer Book T100TAF Keyboard Replacement: 7 단계, 이미지 1개 중 1개
      • Peel the yellow tape and label away from the motherboard with the metal spudger.
      댓글 쓰기
    8. Asus Transformer Book T100TAF Keyboard Replacement: 8 단계, 이미지 1개 중 1개
      • Unplug the cable which leads to the hinge by gently pulling it away from the motherboard.
      댓글 쓰기
    9. Asus Transformer Book T100TAF Keyboard Replacement: 9 단계, 이미지 3개 중 1개 Asus Transformer Book T100TAF Keyboard Replacement: 9 단계, 이미지 3개 중 2개 Asus Transformer Book T100TAF Keyboard Replacement: 9 단계, 이미지 3개 중 3개
      • Flip up the tab on the white ribbon cable labeled “MB” using the metal spudger and then pull the white ribbon cable away from the motherboard.
      • Use a spudger to carefully flip up the black tab on the ZIF connector and pull the black striped ribbon cable away from the motherboard.
      • Don't use a metal spudger for work on the internals of your laptop. The photo in this guide is incorrect. The metal spudger is not ESD safe and could harm the components in your laptop.
      댓글 쓰기
    10. Asus Transformer Book T100TAF Keyboard Replacement: 10 단계, 이미지 1개 중 1개
      • Gently remove the motherboard from the keyboard by pulling up with even pressure applied to all sides of the board.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 6명이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Elizabeth
회원 가입일: 10/01/16
589 평판
안내서 3개를 작성함
USF Tampa, Team 4-3, Passmore Fall 2016 USF Tampa, Team 4-3, Passmore Fall 2016 회원
USFT-PASSMORE-F16S4G3
4 회원들
안내서 20개를 작성함
1가이드 댓글
Très facile. Merci. Et le fait d'avoir pu démonter mon clavier et souffler la poussière à l'intérieur à fait en sorte que les touches qui ne fonctionnaient plus ont recommencé à le faire. Merci encore.
Etienne Olemba - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 31
전체 시간: 7,951
