주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement
필요한 것
    1. Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement, Asus Transformer Pad Infinity Teardown: 1 단계, 이미지 1개 중 1개
      • First, turn the power off
      댓글 쓰기
    2. Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: 2 단계, 이미지 3개 중 1개 Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: 2 단계, 이미지 3개 중 2개 Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: 2 단계, 이미지 3개 중 3개
      • Insert a small flat head screwdriver into the 2 docking station guide ports on the bottom of the tablet.
      • Unlock screen casing tabs
      • Push tab with screwdriver to the right until it clicks
      • You should see a small arrow in the bottom of the port
      • Unlock the tabs in both docking station guide ports.
      댓글 쓰기
    3. Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: 3 단계, 이미지 3개 중 1개 Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: 3 단계, 이미지 3개 중 2개 Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: 3 단계, 이미지 3개 중 3개
      • Use spudger to push upward on the small plastic tabs on top of the docking station guide ports.
      • Insert the flat side of another spudger to start freeing the bottom of the screen from the case.
      댓글 쓰기
    4. Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: 4 단계, 이미지 3개 중 1개 Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: 4 단계, 이미지 3개 중 2개 Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: 4 단계, 이미지 3개 중 3개
      • Use your spudger to open the four plastic tabs located on either side of the tablet.
      • These tabs are very fragile.
      • Remove the screen from the body
      댓글 쓰기
    5. Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: 5 단계, 이미지 2개 중 1개 Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: 5 단계, 이미지 2개 중 2개
      • There is an internal power switch next to the battery connector, that will kill power to the entire device while you're working on it.
      • Don't forget to switch it back on when you're reassembling!
      댓글 쓰기
    6. Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: 6 단계, 이미지 3개 중 1개 Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: 6 단계, 이미지 3개 중 2개 Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: 6 단계, 이미지 3개 중 3개
      • Use your spudger to release the two digitizer ribbon cables from the mainboard.
      • Located on the left side of the tablet between the micro-HDMI and the microSD slot.
      • Use your spudger to release the LCD cable from the back of the LCD.
      • Set aside for later dissection.
      댓글 쓰기
    7. Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: 7 단계, 이미지 3개 중 1개 Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: 7 단계, 이미지 3개 중 2개 Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: 7 단계, 이미지 3개 중 3개
      • To remove the front facing camera (right):
      • Use your spudger to unlock the ribbon cable
      • Slide the camera out
      • To remove the rear facing camera (top):
      • Apply light lifting pressure to unplug it from it's socket
      • Remove the backup battery on the right side:
      • Unplug the cable from the motherboard with your spudger
      댓글 쓰기
    8. Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: 8 단계, 이미지 3개 중 1개 Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: 8 단계, 이미지 3개 중 2개 Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: 8 단계, 이미지 3개 중 3개
      • Remove the motherboard, daughterboard, and dock connector
      • Unscrew 14 points
      • Unplug the speaker from the motherboard before removing it
      • Reveal the battery connector:
      • Flip the motherboard from the top edge of the tablet down (towards the battery).
      • Unplug with light pressure from your spudger.
      • Disconnect the motherboard from the daughterboard:
      • Unlock the ribbon cable on the back side of the daughterboard
      댓글 쓰기
    9. Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: 9 단계, 이미지 3개 중 1개 Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: 9 단계, 이미지 3개 중 2개 Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: 9 단계, 이미지 3개 중 3개
      • Remove the battery:
      • Remove screws (eight)
      • Use your spudger underneath the battery between the 2 cells to work it free
      댓글 쓰기
    10. Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: 10 단계, 이미지 3개 중 1개 Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: 10 단계, 이미지 3개 중 2개 Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: 10 단계, 이미지 3개 중 3개
      • Remove the speaker:
      • Use your spudger underneath, and work it free
      • Remove the bottom screen locking mechanism:
      • Lift pieces out
      댓글 쓰기
    11. Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: 11 단계, 이미지 3개 중 1개 Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: 11 단계, 이미지 3개 중 2개 Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: 11 단계, 이미지 3개 중 3개
      • Now that we're left with a boring empty shell, let's return to the LCD assembly that we set aside in Step 5.
      • Remove the 4 screws. Then work your spudger underneath the edges of the LCD to separate it from the Gorilla Glass front. It has a light adhesive around all edges.
      댓글 쓰기
    12. Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: 12 단계, 이미지 2개 중 1개 Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: 12 단계, 이미지 2개 중 2개
      • With the LCD free, you should now be able to lay it out in a big pile of parts and the teardown is complete. Now let's see what's under all those heatsinks and tape.
      댓글 쓰기
    13. Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: 13 단계, 이미지 2개 중 1개 Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: 13 단계, 이미지 2개 중 2개
      • The back side of the motherboard
      댓글 쓰기
    14. Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: 14 단계, 이미지 3개 중 1개 Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: 14 단계, 이미지 3개 중 2개 Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: 14 단계, 이미지 3개 중 3개
      • Motherboard backside closeups
      댓글 쓰기
    15. Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: 15 단계, 이미지 2개 중 1개 Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: 15 단계, 이미지 2개 중 2개
      • The front side of the motherboard is where all the action is.
      • Tegra 3 quad core processor T33-P-A3
      • 2x Elpida memory J4216EBBG-GNL-F
      • Realtek? ALCS631
      • Hynix H26M64002BNR e-NAND
      댓글 쓰기
    16. Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: 16 단계, 이미지 3개 중 1개 Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: 16 단계, 이미지 3개 중 2개 Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: 16 단계, 이미지 3개 중 3개
      • Front side motherboard closeups
      댓글 쓰기
    17. Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: 17 단계, 이미지 2개 중 1개 Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: 17 단계, 이미지 2개 중 2개
      • Front and back of the daughterboard.
      댓글 쓰기
    18. Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: 18 단계, 이미지 2개 중 1개 Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: 18 단계, 이미지 2개 중 2개
      • The back of the LCD.
      댓글 쓰기
    19. Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: 19 단계, 이미지 3개 중 1개 Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: 19 단계, 이미지 3개 중 2개 Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: 19 단계, 이미지 3개 중 3개
      • Close-ups.
      • That's all I've got. I apologize for any blurry pics as all I had on hand was my cell phone ( <3 Samsung Galaxy Note.) I hope your teardowns are far less destructive than mine was. Good Luck.
      • ...and yes, it still works after reassembly. Thanks for asking.
      댓글 쓰기
    1. Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement, Rear/Front Facing Camera: 20 단계, 이미지 1개 중 1개
      • Disconnect the camera connectors from the board.
      댓글 쓰기
    2. Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: 21 단계, 이미지 3개 중 1개 Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: 21 단계, 이미지 3개 중 2개 Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: 21 단계, 이미지 3개 중 3개
      • Flip the pieces that secure the ribbons to the motherboard up. This is for the front facing camera.
      • Before removing the ribbon connectors, check for a release mechanism. Also make sure it is not a ZIF connector. Doing so can help prevent permanet damage.
      • Take out the ribbon connected to the motherboard. Pull the ribbon cable straight out of the soket to disconnect them.
      • Only follow what is needed for the camera you are replacing. If both cameras need replacement, do both steps. Otherwise, follow the one designated for the camera you need to replace.
      • The first photo shows the overall image. The second photo shows the step for the front-facing camera. The third photo shows the step for the rear camera.
      댓글 쓰기
    3. Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: 22 단계, 이미지 1개 중 1개
      • Take the both cameras out of tablet.
      댓글 쓰기
결론
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
취소: 해당 안내서를 완성하지 않았습니다.
작성자
8다른 기여자 명과 함께
Allison Poh
회원 가입일: 10/20/15
549 평판
안내서 5개를 작성함
UMass Dartmouth, Team 5-1, Gulbrandsen Fall 2015 UMass Dartmouth, Team 5-1, Gulbrandsen Fall 2015 회원
UMASSD-GULBRANDSEN-F15S5G1
3 회원들
안내서 25개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 38
전체 시간: 855
