주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Asus UL80J Key Replacement
필요한 것
  1. Asus UL80J Key Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Place laptop face down with battery facing up.
    댓글 쓰기
  2. Asus UL80J Key Replacement: 2 단계, 이미지 1개 중 1개
    • Slide unlock button to the right.
    댓글 쓰기
  3. Asus UL80J Key Replacement: 3 단계, 이미지 3개 중 1개 Asus UL80J Key Replacement: 3 단계, 이미지 3개 중 2개 Asus UL80J Key Replacement: 3 단계, 이미지 3개 중 3개
    • Slide the button marked with an arrow to the left. The battery should now unclick. Slide the battery away from the laptop to remove it.
    댓글 쓰기
  4. Asus UL80J Key Replacement, Keyboard: 4 단계, 이미지 1개 중 1개
    • Insert a plastic opening tool or a flat-head screwdriver between the laptop body and the keyboard.
    댓글 쓰기
  5. Asus UL80J Key Replacement: 5 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    Plastic Cards
    $2.99
    • Gently pry the keyboard up. This will allow you to unclip the keyboard.
    • Use an old plastic card or a similar flat object to prevent the keyboard from clipping back in while carefully working along the keyboard perimeter.
    • Unclipping sounds are normal.
    댓글 쓰기
    • Keep unclipping the keyboard along the perimeter. Once the keyboard is unclipped, be careful and do not take it out right away, as there is still a ribbon that connects the keyboard with the rest of the computer located on the bottom.
    댓글 쓰기
  6. Asus UL80J Key Replacement: 7 단계, 이미지 1개 중 1개
    • Slowly lift the keyboard and use flash light if needed to locate the ribbon cable on the bottom. Lift the ZIF connector tab before pulling the ribbon cable out.
    • Remove the tape from the ribbon cable if needed and remove the keyboard.
    댓글 쓰기
  7. Asus UL80J Key Replacement, Key: 8 단계, 이미지 2개 중 1개 Asus UL80J Key Replacement, Key: 8 단계, 이미지 2개 중 2개
    • Gently insert the plastic opening tool between the key cap and the hinge. Slowly push the screwdriver up. The key should pop up easily.
    댓글 쓰기
    • Clean the surface underneath the key with a soft brush or condensed air.
    댓글 쓰기
    • Insert the new key in place of the old key. Ensure the clipping sound occurs.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
3다른 기여자 명과 함께
Kateryna Turchenko
회원 가입일: 02/20/17
201 평판
안내서 2개를 작성함
USF Tampa, Team S2-G4, Lacy Spring 2017 USF Tampa, Team S2-G4, Lacy Spring 2017 회원
USFT-LACY-S17S2G4
3 회원들
안내서 7개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 25
전체 시간: 556
