주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Asus UL80J Screen Replacement
필요한 것
  1. Asus UL80J Screen Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Place laptop face down with battery facing up.
    댓글 쓰기
  2. Asus UL80J Screen Replacement: 2 단계, 이미지 1개 중 1개
    • Slide unlock button to the right.
    댓글 쓰기
  3. Asus UL80J Screen Replacement: 3 단계, 이미지 3개 중 1개 Asus UL80J Screen Replacement: 3 단계, 이미지 3개 중 2개 Asus UL80J Screen Replacement: 3 단계, 이미지 3개 중 3개
    • Slide the button marked with an arrow to the left. The battery should now unclick. Slide the battery away from the laptop to remove it.
    댓글 쓰기
  4. Asus UL80J Screen Replacement, Screen: 4 단계, 이미지 3개 중 1개 Asus UL80J Screen Replacement, Screen: 4 단계, 이미지 3개 중 2개 Asus UL80J Screen Replacement, Screen: 4 단계, 이미지 3개 중 3개
    • Flip laptop back over and open it so that the screen faces you. Several rubber cushions hide screws around the bezel (surrounding frame). Remove these first to get to the screws underneath. The two bottom covers are stickers. Then remove all screws holding the bezel in place.
    • There will be four 3 mm screws located on the top and two 5 mm screws located on the bottom of the bezel.
    댓글 쓰기
  5. Asus UL80J Screen Replacement: 5 단계, 이미지 2개 중 1개 Asus UL80J Screen Replacement: 5 단계, 이미지 2개 중 2개
    • Next, completely remove the bezel using a plastic opening tool to work your way around while gently prying it from the LCD. If it does not come off with a moderate amount of force check that you did not miss any screws.
    댓글 쓰기
  6. Asus UL80J Screen Replacement: 6 단계, 이미지 1개 중 1개
    • Unscrew the four 3 mm screws that hold the mounting brackets for the screen to the backing.
    댓글 쓰기
  7. Asus UL80J Screen Replacement: 7 단계, 이미지 1개 중 1개
    • Gently lay the screen on the keyboard and remove the tape over the connection. You can then disconnect the screen.
    댓글 쓰기
결론
To reassemble your device, follow these instructions in reverse order. It is a good idea to check that the new screen works before reattaching the bezel.
취소: 해당 안내서를 완성하지 않았습니다.
작성자
3다른 기여자 명과 함께
Loren Plopper
회원 가입일: 02/19/17
213 평판
안내서 2개를 작성함
USF Tampa, Team S2-G4, Lacy Spring 2017 USF Tampa, Team S2-G4, Lacy Spring 2017 회원
USFT-LACY-S17S2G4
3 회원들
안내서 7개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 6
지난 30일: 33
전체 시간: 583
