주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Asus VivoTab RT TF600T LCD Screen Replacement
필요한 것
    1. Asus VivoTab RT TF600T LCD Screen  Replacement, LCD Screen: 1 단계, 이미지 3개 중 1개 Asus VivoTab RT TF600T LCD Screen  Replacement, LCD Screen: 1 단계, 이미지 3개 중 2개 Asus VivoTab RT TF600T LCD Screen  Replacement, LCD Screen: 1 단계, 이미지 3개 중 3개
      • Make sure the tablet is turned off.
      • Remove the tablet from the attached keyboard.
      • To remove the keyboard, simply depress the switch on the left side of the screen and pull the tablet portion off.
      댓글 쓰기
    2. Asus VivoTab RT TF600T LCD Screen  Replacement: 2 단계, 이미지 3개 중 1개 Asus VivoTab RT TF600T LCD Screen  Replacement: 2 단계, 이미지 3개 중 2개 Asus VivoTab RT TF600T LCD Screen  Replacement: 2 단계, 이미지 3개 중 3개
      • Rotate the device 180°, and remove the two 1.59 mm screws at the bottom of the device.
      • Use the Phillips screwdriver size #000 to remove the two 1.59 mm screws.
      댓글 쓰기
    3. Asus VivoTab RT TF600T LCD Screen  Replacement: 3 단계, 이미지 2개 중 1개 Asus VivoTab RT TF600T LCD Screen  Replacement: 3 단계, 이미지 2개 중 2개
      • Use the plastic opening tool to help detach the screen from the back panel.
      • Insert the plastic opening tool into the bottom right corner and gently start to pry off the screen.
      • Once the screen begins to separate from the body of the device, start working the tool around the outer edges until the entire screen becomes detached.
      댓글 쓰기
    4. Asus VivoTab RT TF600T LCD Screen  Replacement: 4 단계, 이미지 2개 중 1개 Asus VivoTab RT TF600T LCD Screen  Replacement: 4 단계, 이미지 2개 중 2개
      • Now that the screen is completely detached, lay the back panel flat on a smooth surface.
      • Lift the screen to view the inside of the tablet.
      댓글 쓰기
    5. Asus VivoTab RT TF600T LCD Screen  Replacement: 5 단계, 이미지 2개 중 1개 Asus VivoTab RT TF600T LCD Screen  Replacement: 5 단계, 이미지 2개 중 2개
      • Before disconnecting the display cables, refer to the image to turn off the switch labeled DIP; this switch is used to de-energize the system.
      • The battery is connected to the motherboard. To avoid any short circuiting of the device, you must place the switch labeled DIP to OFF.
      댓글 쓰기
    6. Asus VivoTab RT TF600T LCD Screen  Replacement: 6 단계, 이미지 3개 중 1개 Asus VivoTab RT TF600T LCD Screen  Replacement: 6 단계, 이미지 3개 중 2개 Asus VivoTab RT TF600T LCD Screen  Replacement: 6 단계, 이미지 3개 중 3개
      • Remove the yellow tape covering the end of the cables.
      댓글 쓰기
    7. Asus VivoTab RT TF600T LCD Screen  Replacement: 7 단계, 이미지 2개 중 1개 Asus VivoTab RT TF600T LCD Screen  Replacement: 7 단계, 이미지 2개 중 2개
      • After lifting the yellow tape, you should be able to see a white strip. The white strip is actually a lever.
      • Use the plastic opening tool to push in the levers.
      댓글 쓰기
    8. Asus VivoTab RT TF600T LCD Screen  Replacement: 8 단계, 이미지 3개 중 1개 Asus VivoTab RT TF600T LCD Screen  Replacement: 8 단계, 이미지 3개 중 2개 Asus VivoTab RT TF600T LCD Screen  Replacement: 8 단계, 이미지 3개 중 3개
      • With all three white levers pushed in, gently pull on each display cable until the cable disconnects.
      댓글 쓰기
    9. Asus VivoTab RT TF600T LCD Screen  Replacement: 9 단계, 이미지 1개 중 1개
      • Lift the screen upwards to remove.
      댓글 쓰기
결론
Congratulations! You have now successfully removed the screen from your device. To attach your new screen and reassemble your device follow these instructions in reverse order.
취소: 해당 안내서를 완성하지 않았습니다.
다른 5명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Brittany
회원 가입일: 10/13/15
490 평판
안내서 2개를 작성함
Sam Houston State, Team 1-2, Blackburne Fall 2015 Sam Houston State, Team 1-2, Blackburne Fall 2015 회원
SHSU-BLACKBURNE-F15S1G2
3 회원들
안내서 30개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 52
전체 시간: 3,718
