주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Asus VivoTab Smart Battery Replacement
필요한 것
    1. Asus VivoTab Smart Battery Replacement, Battery: 1 단계, 이미지 3개 중 1개 Asus VivoTab Smart Battery Replacement, Battery: 1 단계, 이미지 3개 중 2개 Asus VivoTab Smart Battery Replacement, Battery: 1 단계, 이미지 3개 중 3개
      • Power off the device before you begin disassembly.
      • Place the device face down on a flat surface.
      • Remove the back panel with the plastic opening tool by sliding the tool around the edge of the panel.
      댓글 쓰기
    2. Asus VivoTab Smart Battery Replacement: 2 단계, 이미지 3개 중 1개 Asus VivoTab Smart Battery Replacement: 2 단계, 이미지 3개 중 2개 Asus VivoTab Smart Battery Replacement: 2 단계, 이미지 3개 중 3개
      이 단계에 사용된 도구:
      • Remove the tape covering the 3 ribbons by peeling it off with your hands or with the tweezers.
      • Carefully detach the ribbons from the device's motherboard by pulling outward using tweezers.
      댓글 쓰기
    3. Asus VivoTab Smart Battery Replacement: 3 단계, 이미지 3개 중 1개 Asus VivoTab Smart Battery Replacement: 3 단계, 이미지 3개 중 2개 Asus VivoTab Smart Battery Replacement: 3 단계, 이미지 3개 중 3개
      • The Philips #00 Screwdriver listed in the recommended tools will fit all the screws.
      • Remove the tape covering the areas marked by the black arrows
      • Remove two 3.7 mm Phillips #00 screws
      • Remove eleven 2.7 mm Phillips #00 screws
      댓글 쓰기
    4. Asus VivoTab Smart Battery Replacement: 4 단계, 이미지 2개 중 1개 Asus VivoTab Smart Battery Replacement: 4 단계, 이미지 2개 중 2개
      • Be careful not to damage the speaker wire.
      • Gently unplug the speaker from the motherboard by grabbing the wire near the plastic white plug with tweezers and gently pulling.
      • Lift up on the speaker with your fingers to remove it.
      댓글 쓰기
    5. Asus VivoTab Smart Battery Replacement: 5 단계, 이미지 1개 중 1개
      • Gently lift the battery pressure plate off of the motherboard.
      댓글 쓰기
    6. Asus VivoTab Smart Battery Replacement: 6 단계, 이미지 2개 중 1개 Asus VivoTab Smart Battery Replacement: 6 단계, 이미지 2개 중 2개
      • Use tweezers to separate the battery tray from the device
      • Lift the battery tray from the device using your hands.
      댓글 쓰기
    7. Asus VivoTab Smart Battery Replacement: 7 단계, 이미지 1개 중 1개
      • The battery is secured to the tray by a strong adhesive. Take care not to bend the tray when removing the battery.
      • Detach the battery from the tray by pulling the battery up from the tray with your hands.
      • If it is very difficult to lift the battery from the tray, you can use a blow dryer to heat the back side of the tray. This will weaken the adhesive and make it easier to remove.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 4명이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Zach Hatten
회원 가입일: 10/06/16
563 평판
안내서 4개를 작성함
USF Tampa, Team 2-4, Sullivan Fall 2016 USF Tampa, Team 2-4, Sullivan Fall 2016 회원
USFT-SULLIVAN-F16S2G4
4 회원들
안내서 5개를 작성함
2가이드 댓글
Hi
So where is the next step ?!
Albert einstein - 답글 공유
Hi
Please answer to me. This is so
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 61
전체 시간: 4,009
