주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Asus VivoTab Smart Digitizer Touch Screen Replacement
필요한 것
    1. Asus VivoTab Smart Digitizer Touch Screen Replacement, Digitizer touch screen: 1 단계, 이미지 3개 중 1개 Asus VivoTab Smart Digitizer Touch Screen Replacement, Digitizer touch screen: 1 단계, 이미지 3개 중 2개 Asus VivoTab Smart Digitizer Touch Screen Replacement, Digitizer touch screen: 1 단계, 이미지 3개 중 3개
      • Power off the device before you begin disassembly.
      • Place the device face down on a flat surface.
      • Remove the back panel with the plastic opening tool by sliding the tool around the edge of the panel.
      댓글 쓰기
    2. Asus VivoTab Smart Digitizer Touch Screen Replacement: 2 단계, 이미지 3개 중 1개 Asus VivoTab Smart Digitizer Touch Screen Replacement: 2 단계, 이미지 3개 중 2개 Asus VivoTab Smart Digitizer Touch Screen Replacement: 2 단계, 이미지 3개 중 3개
      이 단계에 사용된 도구:
      • Remove thirteen 3.7 mm Phillips #00 screws
      • Unplug the middle, red-tipped ribbon from the device by lifting up on it. This can be done with your hands or with tweezers.
      • The ribbons are fragile. Take care not to damage the ribbon while removing it.
      댓글 쓰기
    3. Asus VivoTab Smart Digitizer Touch Screen Replacement: 3 단계, 이미지 3개 중 1개 Asus VivoTab Smart Digitizer Touch Screen Replacement: 3 단계, 이미지 3개 중 2개 Asus VivoTab Smart Digitizer Touch Screen Replacement: 3 단계, 이미지 3개 중 3개
      • Unplug the camera ribbon by pulling out on it with a pair of tweezers.
      • Unplug the double ribbon from the device by pulling out on it with a pair of tweezers.
      • The ribbons are fragile. Take care not to tear or damage the ribbons when removing them from the device.
      댓글 쓰기
    4. Asus VivoTab Smart Digitizer Touch Screen Replacement: 4 단계, 이미지 3개 중 1개 Asus VivoTab Smart Digitizer Touch Screen Replacement: 4 단계, 이미지 3개 중 2개 Asus VivoTab Smart Digitizer Touch Screen Replacement: 4 단계, 이미지 3개 중 3개
      • Carefully lift the internal base of the device from the screen, also threading the ribbons through the slots.
      • Be sure to remove the tape above the right ribbon (not shown here) and pull it through the frame like the one in the middle. Not removing the tape can cause the ribbon to tear, possibly destroying the charging board.
      • The ribbons are fragile. Take care not to damage the ribbons when removing the base of the device.
      댓글 쓰기
    5. Asus VivoTab Smart Digitizer Touch Screen Replacement: 5 단계, 이미지 2개 중 1개 Asus VivoTab Smart Digitizer Touch Screen Replacement: 5 단계, 이미지 2개 중 2개
      • Remove four 2.7 mm Phillips #00 screws.
      댓글 쓰기
    6. Asus VivoTab Smart Digitizer Touch Screen Replacement: 6 단계, 이미지 3개 중 1개 Asus VivoTab Smart Digitizer Touch Screen Replacement: 6 단계, 이미지 3개 중 2개 Asus VivoTab Smart Digitizer Touch Screen Replacement: 6 단계, 이미지 3개 중 3개
      • Carefully use tweezers to lift the LCD screen from the digitizer touch screen.
      • Use caution when touching the LCD screen with your hands. It may leave unwanted residue and finger prints.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
9다른 기여자 명과 함께
Zach Hatten
회원 가입일: 10/06/16
563 평판
안내서 4개를 작성함
USF Tampa, Team 2-4, Sullivan Fall 2016 USF Tampa, Team 2-4, Sullivan Fall 2016 회원
USFT-SULLIVAN-F16S2G4
4 회원들
안내서 5개를 작성함
2가이드 댓글
Attention: this procedure has a big trap, in which I fell by following it: I have broken the glued connection between USB/power plug-in unit (on the right-side bottom) and its strip cable (visible on the right side and going into a whole on the right side bottom). Result: when I finished the assembly and tried to start the tablet, I only get the 3 blinking of the power LED, saying the the power connection is not OK.
The instructions should mention, that we have to disconnect also the power/USB strip-cable and take it out the whole, without braking the glued connection !!! - So, the photo in Etape 5 should show also the strip-cable still connected to the USB/power plug-in unit (green element on right-side bottom) !! - This in not the case on your Etape 5 photo and I am wondering how you could re-establish this connection when re-assembling the board.
Consequence: I have to find and buy a new power/USB connector (called DC board) which has the strip-cable included, i.e. attached.
Really annoying !
Richard - 답글 공유
I don’t like this tutorial.
First: as Richard mentioned be very careful to get the flex out of the USB/power plug-in-unit. I broke it as well. It’s a newby thing. Doesn’t matter, it is easy to buy a new one but it takes time off course.
Second: This tutorial has the title of replacing the ** digitizer** but suggests to buy an LCD . Likely many people don’t need to buy a new LCD but a only a reliable digitizer (that’s the frame basically).
Third: Be very cautious about buying a new digitizer. Maybe for a reason it is not part of this tutorial. So you want to replace the digitizer, but there is not a digitizer sold as a part in this tuturial?! Weird. Anyway: I read there were THREE variations of this digitizer, and you really have to buy the one that fits your tablet. Others won’t work. So I suggest to read the flex. I have done this step, and now bought a new, original, digitizer for this tablet. But according a pro it still isn’t a safe buy. I don’t know if he is right, he might be though.
JustBe - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 13
지난 30일: 85
전체 시간: 6,090
