주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Asus X200MA Fan Replacement
필요한 것
  1. Asus X200MA Fan Replacement, Back Panel: 1 단계, 이미지 1개 중 1개
    • Remove the following six screws:
    • Six 4 mm screws using a Phillips #0 screwdriver.
    • Remove the following one screw:
    • One 14 mm screw using a Phillips #0 screwdriver.
    • The 14mm screw goes in the center.
    댓글 쓰기
  2. Asus X200MA Fan Replacement: 2 단계, 이미지 1개 중 1개
    • Take two rubber caps off the back side of the laptop.
    • Use a Phillips #0 screwdriver to remove the two 14 mm screws under the rubber caps.
    댓글 쓰기
  3. Asus X200MA Fan Replacement: 3 단계, 이미지 1개 중 1개
    • Use a plastic or metal spudger to separate the keyboard from the back panel and lift the keyboard out of place.
    댓글 쓰기
  4. Asus X200MA Fan Replacement, Battery: 4 단계, 이미지 1개 중 1개
    댓글 쓰기
  5. Asus X200MA Fan Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the following two screws under the rubber caps.
    • Two 14 mm screws using the Phillips #0 screw driver.
    댓글 쓰기
  6. Asus X200MA Fan Replacement: 6 단계, 이미지 1개 중 1개
    • Flip up the following:
    • The two latches holding the two cables shown(white and black)
    • Pull the cables free from the latches
    • Lift the keyboard from the computer
    댓글 쓰기
  7. Asus X200MA Fan Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the following screws from the inside of the laptop:
    • Two 4 mm screws using the Phillips #0 phillips screwdriver.
    • One 5 mm screw using the Phillips #0 Phillips screwdriver located in the center a little below the battery.
    댓글 쓰기
  8. Asus X200MA Fan Replacement: 8 단계, 이미지 1개 중 1개
    • Slide the battery up and out.
    댓글 쓰기
  9. Asus X200MA Fan Replacement, Fan: 9 단계, 이미지 1개 중 1개
    • Remove the Two 4 mm screws using Phillips #0 phillips screwdriver.
    댓글 쓰기
  10. Asus X200MA Fan Replacement: 10 단계, 이미지 2개 중 1개 Asus X200MA Fan Replacement: 10 단계, 이미지 2개 중 2개
    • Unplug the set of wires located at bottom corner on fan.
    댓글 쓰기
  11. Asus X200MA Fan Replacement: 11 단계, 이미지 2개 중 1개 Asus X200MA Fan Replacement: 11 단계, 이미지 2개 중 2개
    • Lift up and out to completely the remove fan component.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Vanessa Garcia
회원 가입일: 01/22/15
1,817 평판
안내서 6개를 작성함
Cal Poly, Team 21-24, Maness Winter 2015 Cal Poly, Team 21-24, Maness Winter 2015 회원
CPSU-MANESS-W15S21G24
4 회원들
안내서 8개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 27
전체 시간: 2,703
