주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Asus X501A-RH31 Keyboard Replacement
필요한 것
  1. Asus X501A-RH31 Keyboard  Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Turn the laptop over so that the back is facing upwards.
    댓글 쓰기
  2. Asus X501A-RH31 Keyboard  Replacement: 2 단계, 이미지 1개 중 1개
    • To unlock the left tab, make sure the tab on the left has red showing.
    댓글 쓰기
  3. Asus X501A-RH31 Keyboard  Replacement: 3 단계, 이미지 2개 중 1개 Asus X501A-RH31 Keyboard  Replacement: 3 단계, 이미지 2개 중 2개
    • To unlock the right tab, push the right slider to the left with one hand.
    • Push the battery out with the other hand.
    댓글 쓰기
  4. Asus X501A-RH31 Keyboard  Replacement, Keyboard: 4 단계, 이미지 2개 중 1개 Asus X501A-RH31 Keyboard  Replacement, Keyboard: 4 단계, 이미지 2개 중 2개
    • Using the Phillips #00 screwdriver unscrew all nine screws from the bottom of the laptop, as well as the additional two screws inside the battery compartment.
    • Nine of the screws are 5 mm long, 4.5 mm in diameter, while two screws closest to the hinges are 7 mm long.
    댓글 쓰기
  5. Asus X501A-RH31 Keyboard  Replacement: 5 단계, 이미지 1개 중 1개
    • Turn the laptop over and open the top so the keyboard is facing you.
    댓글 쓰기
  6. Asus X501A-RH31 Keyboard  Replacement: 6 단계, 이미지 2개 중 1개 Asus X501A-RH31 Keyboard  Replacement: 6 단계, 이미지 2개 중 2개
    • Pry off the keyboard cover on the edge using the plastic opening tool.
    • Start from one side. Once it is lose, carry out the same procedure on the front and other side.
    • Only do little sections at a time as the keyboard may break if you attempt to take the whole thing off from a single point.
    댓글 쓰기
  7. Asus X501A-RH31 Keyboard  Replacement: 7 단계, 이미지 1개 중 1개
    • Slowly lift the keyboard upward, but do not remove completely.
    • Remove the two data cables that attach the keyboard to the motherboard.
    댓글 쓰기
  8. Asus X501A-RH31 Keyboard  Replacement: 8 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Use tweezers to pull the white plastic piece up that is attached to the data cable.
    • Repeat this process for the big black cable as well.
    • Use caution when unlatching the data cables from the motherboard. The cables are extremely delicate and can break.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Romana Hruby
회원 가입일: 10/20/17
596 평판
안내서 5개를 작성함
UMass Dartmouth, Team S3-G3, Bailey Fall 2017 UMass Dartmouth, Team S3-G3, Bailey Fall 2017 회원
UMASSD-BAILEY-F17S3G3
3 회원들
안내서 8개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 26
전체 시간: 1,552
