주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Asus X751L Wireless Card Replacement
필요한 것
  1. Asus X751L Wireless Card Replacement, Keyboard: 1 단계, 이미지 1개 중 1개
    • With the screen closed, place your laptop upside-down with the front facing you.
    • Remove the six 14.6mm Phillips #00 screws.
    • Remove the four 6.6mm Phillips #00 screws.
    댓글 쓰기
  2. Asus X751L Wireless Card Replacement: 2 단계, 이미지 1개 중 1개
    • Flip the laptop over and open the lid.
    • Pry around the edges of the laptop base using the plastic opening tool.
    • Prying too hard can break the plastic clips.
    댓글 쓰기
  3. Asus X751L Wireless Card Replacement: 3 단계, 이미지 3개 중 1개 Asus X751L Wireless Card Replacement: 3 단계, 이미지 3개 중 2개 Asus X751L Wireless Card Replacement: 3 단계, 이미지 3개 중 3개
    • Carefully lift the keyboard up.
    • Be very careful when lifting the keyboard up. Two zero insertion force (ZIF) cables are between the keyboard assembly and the motherboard. Do not lift the assembly too high.
    • Disconnect the two ZIF connectors from the motherboard using your fingernail to lift the cream-colored tab.
    댓글 쓰기
  4. Asus X751L Wireless Card Replacement, Wireless Card: 4 단계, 이미지 1개 중 1개
    • Remove the single 4.7mm PH00 screw holding the wireless card to the motherboard.
    댓글 쓰기
  5. Asus X751L Wireless Card Replacement: 5 단계, 이미지 1개 중 1개
    • Using your fingers, lightly lift up on the black and white antenna cords.
    댓글 쓰기
  6. Asus X751L Wireless Card Replacement: 6 단계, 이미지 1개 중 1개
    • With your fingers lightly pull the wireless card out of the slot.
    • Make sure to keep the card parallel with the motherboard when removing from the slot.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Matthew Martin
회원 가입일: 02/02/17
217 평판
안내서 1개를 작성함
USF Tampa, Team 17-2, Blackwell Spring 2017 USF Tampa, Team 17-2, Blackwell Spring 2017 회원
USFT-BLACKWELL-S17S17G2
4 회원들
안내서 5개를 작성함
1가이드 댓글
I feel the existing WiFi card is not very good. Is there is better one I can get for the Asus X751L?
July 3, 2023.
cookbake2 - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 37
전체 시간: 2,809
