주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Asus Zenbook UX21e Solid-State Drive Replacement
필요한 것
  1. Asus Zenbook UX21e Solid-State Drive Replacement, Battery: 1 단계, 이미지 3개 중 1개 Asus Zenbook UX21e Solid-State Drive Replacement, Battery: 1 단계, 이미지 3개 중 2개 Asus Zenbook UX21e Solid-State Drive Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Using a T4 Torx screwdriver, unscrew the ten screws lining the bottom cover. Then, proceed to remove the bottom cover by sliding it out parallel toward the back of the computer.
    • There are two length of screws. Eight screws are 3mm and two are 5mm. The two 5mm screws always go into the two center holes along the back edge.
    댓글 쓰기
  2. Asus Zenbook UX21e Solid-State Drive Replacement: 2 단계, 이미지 3개 중 1개 Asus Zenbook UX21e Solid-State Drive Replacement: 2 단계, 이미지 3개 중 2개 Asus Zenbook UX21e Solid-State Drive Replacement: 2 단계, 이미지 3개 중 3개
    • Using an iFixit opening tool and your other hand, gently lift the connector up from the tape wrapped around the connector wires and pry the connector from the motherboard.
    댓글 쓰기
  3. Asus Zenbook UX21e Solid-State Drive Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the battery by unscrewing the five 3mm screws using a Phillips #1 screwdriver.
    • One at each corner and one in the center.
    댓글 쓰기
  4. Asus Zenbook UX21e Solid-State Drive Replacement: 4 단계, 이미지 2개 중 1개 Asus Zenbook UX21e Solid-State Drive Replacement: 4 단계, 이미지 2개 중 2개
    • Lift the battery directly up and remove it from the device.
    댓글 쓰기
  5. Asus Zenbook UX21e Solid-State Drive Replacement, Solid-State Drive: 5 단계, 이미지 3개 중 1개 Asus Zenbook UX21e Solid-State Drive Replacement, Solid-State Drive: 5 단계, 이미지 3개 중 2개 Asus Zenbook UX21e Solid-State Drive Replacement, Solid-State Drive: 5 단계, 이미지 3개 중 3개
    • Unscrew the single 3mm screw with a Phillips #1 screwdriver at the rightmost edge of the Hard Drive.
    • Remove the Hard Drive by sliding it parallel to the motherboard.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
7다른 기여자 명과 함께
Zachary Eslick
회원 가입일: 04/23/18
756 평판
안내서 5개를 작성함
Cal Poly, Team S22-G1, Maness Spring 2018 Cal Poly, Team S22-G1, Maness Spring 2018 회원
CPSU-MANESS-S18S22G1
3 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 11
지난 30일: 53
전체 시간: 5,244
