주요 콘텐츠로 건너뛰기
Asus Zenbook UX31E Charging Port Replacement
필요한 것
  1. Asus Zenbook UX31E Charging Port Replacement, Back Cover: 1 단계, 이미지 1/1
    • Using a T4 Torx screwdriver, remove the ten screws at the marked locations.
    • Place the screws into a container as to not lose them.
  2. Asus Zenbook UX31E Charging Port Replacement: 2 단계, 이미지 1/1
    • Carefully slide your iFixit Opening Tool between the back panel.
    • Lift the back plate of your ASUS ZenBook UX31E, and place it to the side.
  3. Asus Zenbook UX31E Charging Port Replacement, Speaker: 3 단계, 이미지 1/1
    • Use the plastic opening tool to pry open the back cover of the laptop.
    • Remove the bottom panel of the laptop.
  4. Asus Zenbook UX31E Charging Port Replacement: 4 단계, 이미지 1/2 Asus Zenbook UX31E Charging Port Replacement: 4 단계, 이미지 2/2
    • Remove the screw connecting the speaker component to the motherboard using the screwdriver.
  5. Asus Zenbook UX31E Charging Port Replacement: 5 단계, 이미지 1/2 Asus Zenbook UX31E Charging Port Replacement: 5 단계, 이미지 2/2
    • Disconnect the sound cable from the motherboard.
  6. Asus Zenbook UX31E Charging Port Replacement: 6 단계, 이미지 1/2 Asus Zenbook UX31E Charging Port Replacement: 6 단계, 이미지 2/2
    • Using the plastic opening tool, pry open the speaker component from the computer.
  7. Asus Zenbook UX31E Charging Port Replacement, Battery: 7 단계, 이미지 1/2 Asus Zenbook UX31E Charging Port Replacement, Battery: 7 단계, 이미지 2/2
    • Disconnect the battery from the motherboard by gently pulling up and down on the connector.
  8. Asus Zenbook UX31E Charging Port Replacement: 8 단계, 이미지 1/2 Asus Zenbook UX31E Charging Port Replacement: 8 단계, 이미지 2/2
    • Using the Phillips #00 screwdriver, remove the screws from the middle and the two corners of the battery.
  9. Asus Zenbook UX31E Charging Port Replacement: 9 단계, 이미지 1/2 Asus Zenbook UX31E Charging Port Replacement: 9 단계, 이미지 2/2
    • Remove the battery. (Picture-1)
    • Picture of what the battery looks like.(Picture-2)
  10. Asus Zenbook UX31E Charging Port Replacement, SSD: 10 단계, 이미지 1/1
    • Attach your Anti-Static Wrist Wrap to something metal as to not shock your system.
    • Peel back the warranty sticker to reveal the screw under it.
    • Using your Phillips #00 Precision Screwdriver, unscrew the screw that you just revealed.
  11. Asus Zenbook UX31E Charging Port Replacement: 11 단계, 이미지 1/2 Asus Zenbook UX31E Charging Port Replacement: 11 단계, 이미지 2/2
    • Using your hand, pull the SSD out from its slot.
  12. Asus Zenbook UX31E Charging Port Replacement, Fan: 12 단계, 이미지 1/2 Asus Zenbook UX31E Charging Port Replacement, Fan: 12 단계, 이미지 2/2
    • Disconnect the ribbon between the IO and the motherboard on both sides.
  13. Asus Zenbook UX31E Charging Port Replacement: 13 단계, 이미지 1/1
    • Disconnect the fan connector from the motherboard.
    • Pull up the clips on the ribbon connectors.
  14. Asus Zenbook UX31E Charging Port Replacement: 14 단계, 이미지 1/2 Asus Zenbook UX31E Charging Port Replacement: 14 단계, 이미지 2/2
    • Unscrew the two screws that are across each other.
  15. Asus Zenbook UX31E Charging Port Replacement: 15 단계, 이미지 1/2 Asus Zenbook UX31E Charging Port Replacement: 15 단계, 이미지 2/2
    • Using a plastic opening tool, lift the fan off of the laptop.
    • You can now use your hands and carefully pull the fan off the laptop.
  16. Asus Zenbook UX31E Charging Port Replacement, Motherboard: 16 단계, 이미지 1/3 Asus Zenbook UX31E Charging Port Replacement, Motherboard: 16 단계, 이미지 2/3 Asus Zenbook UX31E Charging Port Replacement, Motherboard: 16 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Remove the 7 screws holding the motherboard in the case with a Phillips #00 screwdriver.
    • Remove the press fit connector attaching the motherboard to the screen.
    • Remove the two cables that are still attached to the motherboard. You will need to use needle nose tweezers to remove these.
  17. Asus Zenbook UX31E Charging Port Replacement: 17 단계, 이미지 1/2 Asus Zenbook UX31E Charging Port Replacement: 17 단계, 이미지 2/2
    • Lift gently and flip the motherboard over in the direction of the track pad.
    • Peel off the the yellow tape.
    • Detach the ZIF connector on the underside of the motherboard connecting it to the keyboard.
    • Remove the motherboard.
  18. Asus Zenbook UX31E Charging Port Replacement, Charging Port: 18 단계, 이미지 1/3 Asus Zenbook UX31E Charging Port Replacement, Charging Port: 18 단계, 이미지 2/3 Asus Zenbook UX31E Charging Port Replacement, Charging Port: 18 단계, 이미지 3/3
  19. Asus Zenbook UX31E Charging Port Replacement: 19 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Pull the charging port up from the motherboard with a pair of tweezers while the solder is still liquid.
결론
다른 2명이 해당 안내서를 완성하였습니다.
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 11
30일 전: 39
전체 시간: 2,766
