소개
If your Asus Zenfone 3 Max phone fails to charge, it could be due to a malfunctioning or damaged device battery. This guide will help you remove your phone battery and replace it with a new one. Before you begin, please note that the replacement of battery must be done with great care, as you can potentially damage other parts of the device. For additional information, access the troubleshooting page here.
When replacing the battery, first make sure it is not swollen. Visit this page in order to learn more and take any necessary precautions.
필요한 것
Using an iFixit opening tool, gently wedge the tool between the phone and the back casing.
Move the opening tool up and down to pry the back off of the device.
Gently disconnect the gold connection cable indicated by the red circle in the corresponding picture.
Pull back on the black adhesive tab that is adhered to the top of the battery. Tab removal is marked in the corresponding picture with a orange circle.
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 3개
I need to replace asus zenfone 3 max whole body lcd & what ever the requirements i want to know that it can be replaced or it is dead
Part not available on amazon & please bring your store to India, as the market is flooded with a ton of counterfeited products.
Asus Zenfone max 3, 5.5 এর ব্র্যাক সেল ও চার্জিং লজিক পাওয়া যাবে কি, জানাবেন প্লিজ
