주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Atari 5200 Game Cartridge Disassembly
필요한 것
  1. Atari 5200 Game Cartridge Disassembly, Opening up the cartridge: 1 단계, 이미지 3개 중 1개 Atari 5200 Game Cartridge Disassembly, Opening up the cartridge: 1 단계, 이미지 3개 중 2개 Atari 5200 Game Cartridge Disassembly, Opening up the cartridge: 1 단계, 이미지 3개 중 3개
    • Flip the cartridge over.
    • Unscrew the single screw on the back.
    • Carefully pry apart the casing. There are six (6) tabs that need to be released, three (3) each side. If you're not careful they will break. (experience has taught me)
    • Set aside any case parts after dissassembly.
    댓글 쓰기
  2. Atari 5200 Game Cartridge Disassembly, Cleaning the Parts: 2 단계, 이미지 1개 중 1개
    • Unscrew the board casing, and remove it.
    • Use a compressed air can to blow off any excess dust off the board.
    • Use an alcohol-dabbed cloth to wipe down the gold-plated contacts of the board.
    댓글 쓰기
  3. Atari 5200 Game Cartridge Disassembly, Reassembly: 3 단계, 이미지 3개 중 1개 Atari 5200 Game Cartridge Disassembly, Reassembly: 3 단계, 이미지 3개 중 2개 Atari 5200 Game Cartridge Disassembly, Reassembly: 3 단계, 이미지 3개 중 3개
    • Place the two contact protectors together.
    • Place the spring on the knob in the cartridge.
    댓글 쓰기
  4. Atari 5200 Game Cartridge Disassembly, Reassembly, Part 2: 4 단계, 이미지 3개 중 1개 Atari 5200 Game Cartridge Disassembly, Reassembly, Part 2: 4 단계, 이미지 3개 중 2개 Atari 5200 Game Cartridge Disassembly, Reassembly, Part 2: 4 단계, 이미지 3개 중 3개
    • Thread the spring into the connected plates.
    • Push the plates into the cartridge against the pressure of the spring.
    댓글 쓰기
  5. Atari 5200 Game Cartridge Disassembly, Finishing up: 5 단계, 이미지 3개 중 1개 Atari 5200 Game Cartridge Disassembly, Finishing up: 5 단계, 이미지 3개 중 2개 Atari 5200 Game Cartridge Disassembly, Finishing up: 5 단계, 이미지 3개 중 3개
    • Place the chip in the case.
    • It should "pop" into place.
    • Screw the other side of the case on.
    댓글 쓰기
결론
Be sure to test the game, and if freezing still occurs, check the contacts once again.
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
10다른 기여자 명과 함께
Zach Petryszyn
회원 가입일: 09/26/14
21 평판
안내서 3개를 작성함
USF Tampa, Team 13-1, Staggers Fall 2014 USF Tampa, Team 13-1, Staggers Fall 2014 회원
USFT-STAGGERS-F14S13G1
5 회원들
안내서 17개를 작성함
2가이드 댓글
I’m curious to see the Atari 2600 cartridge inside but I can’t get my hands on one.
The official meme centre. - 답글 공유
it's not a 2600 cart. the systems have similarities, but they are not pin compatible, nor are they software compatible. the 5200 is its own thing.
Gorilla Sapiens - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 10
지난 30일: 53
전체 시간: 4,049
