주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Audio-Technica AT-LP120XUSB Velocity PCB Replacement
필요한 것
    1. Audio-Technica AT-LP120XUSB Velocity PCB Replacement, Prepare Turntable: 1 단계, 이미지 3개 중 1개 Audio-Technica AT-LP120XUSB Velocity PCB Replacement, Prepare Turntable: 1 단계, 이미지 3개 중 2개 Audio-Technica AT-LP120XUSB Velocity PCB Replacement, Prepare Turntable: 1 단계, 이미지 3개 중 3개
      • Disconnect any cables from the rear of the turntable and move it to a clear surface.
      • With the turntable facing you, remove the following accessories and tie down the tonearm:
      • Dust Cover & Hinges
      • Black felt mat
      • Platter
      • Headshell & Counterweight
      • 45 Adapter
      • Any other loose accessories that may be on the surface of the turntable should be removed.
      댓글 쓰기
    2. Audio-Technica AT-LP120XUSB Velocity PCB Replacement, Removing Bottom Cover: 2 단계, 이미지 1개 중 1개
      • Before flipping the turntable upside-down, get a large soft object (ex. pillow, blanket, etc...) to minimize the possibility of damage.
      • Using a #PH1 Screwdriver, remove the 13 screws marked
      • Using a #PH0 Screwdriver, remove the 2 screws marked.
      댓글 쓰기
    3. Audio-Technica AT-LP120XUSB Velocity PCB Replacement, Velocity PCB Location and Removal: 3 단계, 이미지 3개 중 1개 Audio-Technica AT-LP120XUSB Velocity PCB Replacement, Velocity PCB Location and Removal: 3 단계, 이미지 3개 중 2개 Audio-Technica AT-LP120XUSB Velocity PCB Replacement, Velocity PCB Location and Removal: 3 단계, 이미지 3개 중 3개
      • With the bottom panel removed, locate the Velocity PCB.
      • Locate the 3 connectors, and remove them from their corresponding PCBs.
      • Using a #PH0 screwdriver, remove these 6 screws.
      • After the screws are removed and connectors are loose, the Velocity PCB can be removed.
      댓글 쓰기
    4. Audio-Technica AT-LP120XUSB Velocity PCB Replacement, Replacing Velocity PCB: 4 단계, 이미지 3개 중 1개 Audio-Technica AT-LP120XUSB Velocity PCB Replacement, Replacing Velocity PCB: 4 단계, 이미지 3개 중 2개 Audio-Technica AT-LP120XUSB Velocity PCB Replacement, Replacing Velocity PCB: 4 단계, 이미지 3개 중 3개
      • Before mounting the 6 screws, plug in the short connector to the Velocity PCB.
      • Mount the Velocity PCB using the guide post, and secure it with the 6 screws.
      • Connect the 2 longer leads to their corresponding PCBs.
      댓글 쓰기
    5. Audio-Technica AT-LP120XUSB Velocity PCB Replacement, Reassembly: 5 단계, 이미지 1개 중 1개
      • Place the bottom cover back on.
      • Using a #PH1 Screwdriver, secure the bottom cover with the 13 longer screws.
      • Using a #PH0 Screwdriver, secure the bottom cover with the 2 shorter screws.
      댓글 쓰기
결론
Once the repair is completed, put all of your accessories back onto the turntable and reconnect any cables you were using.
For assistance balancing your tonearm, follow the guide attached below.
취소: 해당 안내서를 완성하지 않았습니다.
작성자
1다른 기여자 명과 함께
ATUS Service Dept
회원 가입일: 04/02/24
764 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 11
지난 30일: 78
전체 시간: 668
