주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Audiovox CDM-8910 Keyboard Replacement
필요한 것
  1. Audiovox CDM-8910 Keyboard Replacement, Antenna: 1 단계, 이미지 1개 중 1개
    • Locate the antenna (shown in red box) at the top of the phone when closed.
    댓글 쓰기
  2. Audiovox CDM-8910 Keyboard Replacement: 2 단계, 이미지 1개 중 1개
    • Using your thumb and index finger, grip the antenna near its base and unscrew counter clockwise. Once loose, remove the antenna by pulling it from its insert hole.
    댓글 쓰기
  3. Audiovox CDM-8910 Keyboard Replacement, Battery: 3 단계, 이미지 1개 중 1개
    • Locate the back side of the phone.
    • The battery is the large main compartment (red box).
    댓글 쓰기
  4. Audiovox CDM-8910 Keyboard Replacement: 4 단계, 이미지 1개 중 1개
    • Use your finger to slide the latch (circled) upwards.
    • While holding the latch up, pull the battery off the phone.
    댓글 쓰기
  5. Audiovox CDM-8910 Keyboard Replacement: 5 단계, 이미지 1개 중 1개
    • The back of the phone will look like this when the battery is correctly removed.
    댓글 쓰기
  6. Audiovox CDM-8910 Keyboard Replacement, Rear Case: 6 단계, 이미지 1개 중 1개
    • Peel the rubber indicated toward the top of the phone
    댓글 쓰기
  7. Audiovox CDM-8910 Keyboard Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the screw that sits underneath the rubber covering.
    댓글 쓰기
  8. Audiovox CDM-8910 Keyboard Replacement: 8 단계, 이미지 1개 중 1개
    • Remove the five (5) total screws using a Philips head screwdriver.
    댓글 쓰기
  9. Audiovox CDM-8910 Keyboard Replacement: 9 단계, 이미지 1개 중 1개
    • Use spudger and insert it towards the bottom of the phone as pictured.
    • Carefully working yourself around the phone with the spudger, pry it open. This may require a bit of force.
    • The volume control button will be loose, so make sure to take it out once the rear case is fully removed.
    댓글 쓰기
  10. Audiovox CDM-8910 Keyboard Replacement: 10 단계, 이미지 1개 중 1개
    • The back case should now be completely removed and the motherboard will be visible.
    댓글 쓰기
  11. Audiovox CDM-8910 Keyboard Replacement, Motherboard: 11 단계, 이미지 3개 중 1개 Audiovox CDM-8910 Keyboard Replacement, Motherboard: 11 단계, 이미지 3개 중 2개 Audiovox CDM-8910 Keyboard Replacement, Motherboard: 11 단계, 이미지 3개 중 3개
    • Disconnect the gold connection patch
    • Use a spudger or finger to disconnect the piece.
    댓글 쓰기
  12. Audiovox CDM-8910 Keyboard Replacement: 12 단계, 이미지 1개 중 1개
    • Using a spudger, lift the motherboard out of the phone case as pictured.
    댓글 쓰기
  13. Audiovox CDM-8910 Keyboard Replacement: 13 단계, 이미지 1개 중 1개
    • The motherboard should now be completely removed from the phone.
    댓글 쓰기
  14. Audiovox CDM-8910 Keyboard Replacement, Keyboard: 14 단계, 이미지 1개 중 1개
    • Once the motherboard has been removed, peel the keyboard as pictured.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
4다른 기여자 명과 함께
Carlos Guerrero
회원 가입일: 10/04/10
1 평판
안내서 2개를 작성함
Cal Poly, Team 3-24, Regan Fall 2010 Cal Poly, Team 3-24, Regan Fall 2010 회원
CPSU-REGAN-F10S3G24
4 회원들
안내서 24개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 10
지난 30일: 27
전체 시간: 1,781
