주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
August Smart Lock Accelerometer Replacement
필요한 것
    1. August Smart Lock Accelerometer Replacement, Accelerometer: 1 단계, 이미지 3개 중 1개 August Smart Lock Accelerometer Replacement, Accelerometer: 1 단계, 이미지 3개 중 2개 August Smart Lock Accelerometer Replacement, Accelerometer: 1 단계, 이미지 3개 중 3개
      • Flip device over so the black bottom is facing you.
      • Undo latches on both sides to remove the metal cover.
      • Using a Phillips #0 screwdriver, remove the black screws to release the back cover.
      • To unscrew all of the screws, you will need to close the latches again.
      • When you lift off the cover, be careful not to lift to far up. The cover contains the speaker which is connected to the motherboard.
      댓글 쓰기
    2. August Smart Lock Accelerometer Replacement: 2 단계, 이미지 3개 중 1개 August Smart Lock Accelerometer Replacement: 2 단계, 이미지 3개 중 2개 August Smart Lock Accelerometer Replacement: 2 단계, 이미지 3개 중 3개
      • Grab the gears and lift them up to remove from the device
      댓글 쓰기
    3. August Smart Lock Accelerometer Replacement: 3 단계, 이미지 3개 중 1개 August Smart Lock Accelerometer Replacement: 3 단계, 이미지 3개 중 2개 August Smart Lock Accelerometer Replacement: 3 단계, 이미지 3개 중 3개
      • Remove the (3) three silver screws by the motor using a Phillips #0 screwdriver.
      • Disconnect the speaker plug from the motherboard
      • Disconnect the battery plugs from the motherboard.
      댓글 쓰기
    4. August Smart Lock Accelerometer Replacement: 4 단계, 이미지 1개 중 1개
      • Once the speaker is disconnected, remove the back cover.
      • Lift up the motherboard and motor assembly out of the device.
      댓글 쓰기
    5. August Smart Lock Accelerometer Replacement: 5 단계, 이미지 2개 중 1개 August Smart Lock Accelerometer Replacement: 5 단계, 이미지 2개 중 2개
      • Locate the Accelerometer. It is attached to the motherboard by a ribbon.
      • Lift up the black tab to remove the ribbon from the motherboard.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 8명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
William Fink
회원 가입일: 09/26/17
841 평판
안내서 3개를 작성함
USF Tampa, Team S11-G6, Passmore Fall 2017 USF Tampa, Team S11-G6, Passmore Fall 2017 회원
USFT-PASSMORE-F17S11G6
4 회원들
안내서 9개를 작성함
7가이드 댓글
Any idea where can I get a new accelerometer to complete this repair?
Thai Nguyen - 답글 공유
Where can we get a new accelerometer. My phone was not connecting because of the ribbon was broken inside
Dinesh Sharma - 답글 공유
Same as above…. where to locate an accelerometer??
osallabe - 답글 공유
Did anyone find out where to buy the part?
LBurd - 답글 공유
Where can I find one
Jeff Wasilewski - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 14
지난 30일: 61
전체 시간: 8,903
