주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Automatic Tommy 20 Dart Accelerator Replacement
필요한 것
    1. Automatic Tommy 20 Dart Accelerator Replacement, Splitting the Gun into Two Halves: 1 단계, 이미지 2개 중 1개 Automatic Tommy 20 Dart Accelerator Replacement, Splitting the Gun into Two Halves: 1 단계, 이미지 2개 중 2개
      • Locate the orange slider on the front side of the gun.
      • Pull the orange slider towards the back of the gun while lifting up on the nose the gun.
      댓글 쓰기
    2. Automatic Tommy 20 Dart Accelerator Replacement: 2 단계, 이미지 3개 중 1개 Automatic Tommy 20 Dart Accelerator Replacement: 2 단계, 이미지 3개 중 2개 Automatic Tommy 20 Dart Accelerator Replacement: 2 단계, 이미지 3개 중 3개
      • Remove the single 1/8 in. screw at the junction of the body and the nose using a Philips #00 Screwdriver.
      • Remove all parts within the chamber to be able to completely detach the nose of the gun.
      • Be careful to keep track of all the components for reassembly.
      댓글 쓰기
    1. Automatic Tommy 20 Dart Accelerator Replacement, Disassembling the Nose of the Gun: 3 단계, 이미지 3개 중 1개 Automatic Tommy 20 Dart Accelerator Replacement, Disassembling the Nose of the Gun: 3 단계, 이미지 3개 중 2개 Automatic Tommy 20 Dart Accelerator Replacement, Disassembling the Nose of the Gun: 3 단계, 이미지 3개 중 3개
      • Remove all five 1/16 in. screws holding the nose of the gun together using a Phillips #00 screwdriver.
      • Look out for the hidden fifth screw behind the thin light green tape near the bushing itself. Peel the tape using your finger to gain access.
      댓글 쓰기
    2. Automatic Tommy 20 Dart Accelerator Replacement, Removing the Bushing: 4 단계, 이미지 1개 중 1개
      • Pick up the now split half of the nose of the gun that does not still have the orange tip attached to it.
      • Remove the bushing by simply pulling it away from the plastic.
      댓글 쓰기
    1. Automatic Tommy 20 Dart Accelerator Replacement, Dart Accelerator: 5 단계, 이미지 2개 중 1개 Automatic Tommy 20 Dart Accelerator Replacement, Dart Accelerator: 5 단계, 이미지 2개 중 2개
      • Unscrew the two screws holding the accelerator in place with a Phillips #00 screwdriver
      댓글 쓰기
    2. Automatic Tommy 20 Dart Accelerator Replacement, Removing the Accelerator: 6 단계, 이미지 1개 중 1개
      • Pull back on the accelerator away from the plastic to remove from frame.
      • Be careful to not pull too quickly or too hard to avoid damaging the wiring.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Reed Garmsen
회원 가입일: 10/07/14
468 평판
안내서 2개를 작성함
Cal Poly, Team 6-22, Maness Fall 2014 Cal Poly, Team 6-22, Maness Fall 2014 회원
CPSU-MANESS-F14S6G22
4 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 7
지난 30일: 34
전체 시간: 1,513
