주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Autosampler Configuration (For Old & New Versions)
    1. Autosampler Configuration  (For Old & New Versions), Starting the configuration process.: 1 단계, 이미지 2개 중 1개 Autosampler Configuration  (For Old & New Versions), Starting the configuration process.: 1 단계, 이미지 2개 중 2개
      • 1. Turn on the autosampler. Screen will read "...STANDBY..."
      • 2. Press "ENTER/PROGRAM" button. Use arrows to highlight "CONFIGURE". Press "ENTER/PROGRAM" button
      • This will allow you to use the arrows to shuffle through the different configuration options. To select the one you want, press the "ENTER/PROGRAM" button.
      댓글 쓰기
    2. Autosampler Configuration  (For Old & New Versions), Configuring "set clock".: 2 단계, 이미지 1개 중 1개
      • The first option for configuring is "SET CLOCK"
      • 3. Press "ENTER/PROGRAM" to "SET CLOCK". Use the numeric keys to set the time and date. You can use the arrows to move. When finished. Press "ENTER/PROGRAM" button.
      댓글 쓰기
    3. Autosampler Configuration  (For Old & New Versions), Configuring "bottles and sizes".: 3 단계, 이미지 1개 중 1개
      • 4. Press "ENTER/PROGRAM" to configure "BOTTLES AND SIZES".
      • Use arrows to select "PORTABLE" sampler. Press "ENTER/PROGRAM" to configure bottles and sizes.
      • Use arrows to select "24" botles. Press "ENTER/PROGRAM" button.
      • Use numeric keys to enter "1000" mL for the "BOTTLE VOLUME". Press "ENTER/PROGRAM" button.
      댓글 쓰기
    4. Autosampler Configuration  (For Old & New Versions), Configuring "suction line".: 4 단계, 이미지 1개 중 1개
      • 5. Press "ENTER/PROGRAM" to configure "SUCTION LINE".
      • Use arrow to select "3/8" inch for "SUCTION LINE I.D." Press "ENTER/PROGRAM" button.
      • Use arrow to select "VINYL" for "SUCTION LINE" type. Press "ENTER/PROGRAM" button.
      • Use numeric keys to enter "25" feet for "SUCTION LINE LENGTH". Press "ENTER/PROGRAM" button.
      • The suction line length may change based on location and should be measured!
      댓글 쓰기
    5. Autosampler Configuration  (For Old & New Versions), Configuring "liquid detector".: 5 단계, 이미지 1개 중 1개
      • 6. Press "ENTER/PROGRAM" button to configure "LIQUID DETECTOR".
      • Use arrows to select "ENABLE" "LIQUID DECTOR". Press "ENTER/PROGRAM" button.
      • Use numeric keys to enter "3" "RINSE CYCLES." Press "ENTER/PROGRAM" button.
      • Screen will read "ENTER HEAD MANUALLY?" Use arrows to select "NO". Press "ENTER/PROGRAM" button.
      • Screen will read "RETRY UP TO X TIMES WHEN SAMPLING?" Use numeric keys to enter "3". Press "ENTER/PROGRAM" button.
      댓글 쓰기
    6. Autosampler Configuration  (For Old & New Versions), Configuring "programming mode".: 6 단계, 이미지 1개 중 1개
      • 7. Press "ENTER/PROGRAM" to configure "PROGRAMMING MODE".
      • Use arrows to select "BASIC" mode. Press "ENTER/PROGRAM" button.
      댓글 쓰기
    7. Autosampler Configuration  (For Old & New Versions), Configuring "calibrate sampler".: 7 단계, 이미지 1개 중 1개
      • 8. Press "ENTER/PROGRAM" to configure "CALIBRATE SAMPLER".
      • Use arrows to select "DISABLE" "CALIBRATE SAMPLER". Press "ENTER/PROGRAM" button.
      댓글 쓰기
    8. Autosampler Configuration  (For Old & New Versions), Configuring "start time delay".: 8 단계, 이미지 1개 중 1개
      • 9. Press "ENTER/PROGRAM" to configure "START TIME DELAY". Press "ENTER/PROGRAM" button.
      • Screen will read "X MINUTE DELAY TO START." Use numeric keys to enter "0" minutes. Press "ENTER/PROGRAM" button.
      댓글 쓰기
    9. Autosampler Configuration  (For Old & New Versions), Configuring "enabling pin".: 9 단계, 이미지 1개 중 1개
      • 10. Press "ENTER/PROGRAM" to configure "ENABLE PIN". Press "ENTER/PROGRAM" button.
      • Use arrow to select "NO" for "MASTER/SLAVE MODE?" Press "ENTER/PROGRAM" button.
      • Use arrow to select "NO" for "SAMPLE UPON DISABLE?" Press "ENTER/PROGRAM" button.
      • Use arrow to select "NO" for "SAMPLE UPON ENABLE?" Press "ENTER/PROGRAM" button.
      • Use arrow to select "NO" for "RESET SAMPLE INTERVAL?" Press "ENTER/PROGRAM" button.
      • Use arrow to select "NO" for "INHIBIT COUNTDOWN?" Press "ENTER/PROGRAM" button.
      댓글 쓰기
    10. Autosampler Configuration  (For Old & New Versions), Configuring "event mark".: 10 단계, 이미지 1개 중 1개
      • 11. Press "ENTER/PROGRAM" to configure "EVENT MARK". Press "ENTER/PROGRAM" button.
      • Use arrow to select "CONTINUOUS SIGNAL". Press "ENTER/PROGRAM" button.
      • Use arrow to select "PUMP CYCLE". Press "ENTER/PROGRAM" button.
      • It is critical this setting is configured in order for the sensor node to operate the autosampler!
      댓글 쓰기
    11. Autosampler Configuration  (For Old & New Versions), Configuring "purge counts".: 11 단계, 이미지 1개 중 1개
      • 12. Press "ENTER/PROGRAM" to configure "PURGE COUNTS". Press "ENTER/PROGRAM" button.
      • Use numeric keys to enter "XX" for "PRE-SAMPLE COUNTS". Press "ENTER/PROGRAM" button.
      • Use numeric keys to enter "XX" for "POST-SAMPLE COUNTS". Press "ENTER/PROGRAM" button.
      댓글 쓰기
    12. Autosampler Configuration  (For Old & New Versions), Configuring "tubing life".: 12 단계, 이미지 1개 중 1개
      • 12. Press "ENTER/PROGRAM" to configure "TUBING LIFE". Press "ENTER/PROGRAM" button.
      • Screen will read "X PUMP COUNTS, WARNING AT XXX000". Press "ENTER/PROGRAM" button.
      • Use arrows to select "NO" for "RESET PUMP COUNTER?". Press "ENTER/PROGRAM" button.
      • Use numeric keys to enter "XXX000" for "PUMP COUNTS TO WARNING". Press "ENTER/PROGRAM" button.
      댓글 쓰기
    13. Autosampler Configuration  (For Old & New Versions), Configuring "program lock".: 13 단계, 이미지 1개 중 1개
      • 13. Press "ENTER/PROGRAM" to configure "PROGRAM LOCK". Press "ENTER/PROGRAM" button.
      • Use arrows to select "DISABLE" "PROGRAM LOCK". Press "ENTER/PROGRAM" button.
      댓글 쓰기
    14. Autosampler Configuration  (For Old & New Versions), Configuring "sampler ID".: 14 단계, 이미지 1개 중 1개
      • 15. The next configuration option is "SAMPLER ID". Skip this configuration step by using the arrows.
      댓글 쓰기
    15. Autosampler Configuration  (For Old & New Versions), Configuring "run diagonostics".: 15 단계, 이미지 1개 중 1개
      • 16. The next configuration option is "RUN DIAGNOSTICS". Skip this configuration step by using the arrows.
      댓글 쓰기
결승점
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Brooke Mason
회원 가입일: 05/29/19
2,958 평판
안내서 17개를 작성함
Open-Storm Open-Storm 회원
Community
14 회원들
안내서 75개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 10
지난 30일: 31
전체 시간: 546
