주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Autosampler Node Wiring (For Old Version)
필요한 것
    1. Autosampler Node Wiring  (For Old Version), Disconnect the batteries completely: 1 단계, 이미지 3개 중 1개 Autosampler Node Wiring  (For Old Version), Disconnect the batteries completely: 1 단계, 이미지 3개 중 2개 Autosampler Node Wiring  (For Old Version), Disconnect the batteries completely: 1 단계, 이미지 3개 중 3개
      • 1. Disconnect the plug to the solar panel.
      • Then, grabbing the green connector, pull the battery connector from the solar charge controller (blue arrow).
      • 2. Disconnect the plugs for the autosampler battery.
      • 3. Disconnect the connector that plugs into the battery port of the sampler.
      • If disconnect battery before solar panel, this can damage the solar charger!
      댓글 쓰기
    2. Autosampler Node Wiring  (For Old Version), Remove old wires: 2 단계, 이미지 2개 중 1개 Autosampler Node Wiring  (For Old Version), Remove old wires: 2 단계, 이미지 2개 중 2개
      • 4. Unscrew conduit and release to open up more space to work with.
      • 5. Unscrew existing wires using 260 / 1.5 x 40 flathead screwdriver.
      댓글 쓰기
    3. Autosampler Node Wiring  (For Old Version), Run wires through enclosure: 3 단계, 이미지 1개 중 1개
      • 6. Pull the autosampler and battery wires through the conduit. Reattach the conduit to provide strain relief and prevent wires from being dragged down.
      댓글 쓰기
    4. Autosampler Node Wiring  (For Old Version), Rewire the autosampler connections: 4 단계, 이미지 3개 중 1개 Autosampler Node Wiring  (For Old Version), Rewire the autosampler connections: 4 단계, 이미지 3개 중 2개 Autosampler Node Wiring  (For Old Version), Rewire the autosampler connections: 4 단계, 이미지 3개 중 3개
      • 7. Insert the wires and screw down using 260 / 1.5 x 40 flathead screwdriver until tight.
      • We do not use the green wire.
      • Hand tight is just right. Be careful not to over-tighten and crush the wire ferrules
      • 8. The battery connectors go in the fifth and sixth positions from the left.
      • If the battery connectors do not have the white caps, they will be only one red and one black wire. To make it easier to connect to the board, trim half of the copper wires off of each wire. and twist the reaming threads together. The red wire goes in the place where the red/white cap goes and the black wire goes where the black/green wire goes.
      댓글 쓰기
    5. Autosampler Node Wiring  (For Old Version), Connect the relay board: 5 단계, 이미지 1개 중 1개
      • 9. Plug in the pluggable header into the board.
      댓글 쓰기
    6. Autosampler Node Wiring  (For Old Version), Tidy up the enclosure: 6 단계, 이미지 3개 중 1개 Autosampler Node Wiring  (For Old Version), Tidy up the enclosure: 6 단계, 이미지 3개 중 2개 Autosampler Node Wiring  (For Old Version), Tidy up the enclosure: 6 단계, 이미지 3개 중 3개
      • 10. Using velcro, re-secure the relay board to the side of the enclosure.
      • 11. Using velcro, attach the lithium ion battery to the inside of the enclosure door.
      • Be sure to clean the surfaces beforehand.
      • Be sure the soft side is attached to the enclosure.
      • 12. In case the wiring of an ultrasonic sensor comes loose, here is the wiring.
      댓글 쓰기
    7. Autosampler Node Wiring  (For Old Version), Reconnect wires to the autosampler.: 7 단계, 이미지 2개 중 1개 Autosampler Node Wiring  (For Old Version), Reconnect wires to the autosampler.: 7 단계, 이미지 2개 중 2개
      • 13. Reconnect the 6-pin autosampler connector.
      • 14. Reconnect the 2-pin autosampler battery to the autosampler.
      댓글 쓰기
    8. Autosampler Node Wiring  (For Old Version), Reconnect the batteries: 8 단계, 이미지 3개 중 1개 Autosampler Node Wiring  (For Old Version), Reconnect the batteries: 8 단계, 이미지 3개 중 2개 Autosampler Node Wiring  (For Old Version), Reconnect the batteries: 8 단계, 이미지 3개 중 3개
      • 15. Reconnect the grey autosampler connector from the autosampler to the node.
      • 16. Reconnect lithium ion battery in the node.
      • 17. Plug in the solar panel into the solar charger last.
      댓글 쓰기
결론
Now we can close and lock up the enclosure. The node is ready to test and confirm everything is working,
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Brandon Wong
회원 가입일: 01/16/18
502 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 26
전체 시간: 925
