주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Autosampler Programming (For Old & New Versions)
    1. Autosampler Programming  (For Old & New Versions), Turn on battery and autosampler: 1 단계, 이미지 2개 중 1개 Autosampler Programming  (For Old & New Versions), Turn on battery and autosampler: 1 단계, 이미지 2개 중 2개
      • 1. Switch battery "ON".
      • 2. Autosampler: Push "ON" button.
      • It will say ...STANDBY...
      댓글 쓰기
    2. Autosampler Programming  (For Old & New Versions), Select Program Mode: 2 단계, 이미지 2개 중 1개 Autosampler Programming  (For Old & New Versions), Select Program Mode: 2 단계, 이미지 2개 중 2개
      • 3. Push "ENTER/PROGRAM" button to see the "[PROGRAM, CONFIGURE] SAMPLER" screen. Push “ENTER/PROGRAM” button to select "PROGRAM".
      • 4. This will bring up the "[TIME, FLOW] PACED SAMPLING" screen. Use arrow to select "FLOW" then push “ENTER/PROGRAM” button.
      댓글 쓰기
    3. Autosampler Programming  (For Old & New Versions), Set Number, Type, and Size of Samples: 3 단계, 이미지 3개 중 1개 Autosampler Programming  (For Old & New Versions), Set Number, Type, and Size of Samples: 3 단계, 이미지 3개 중 2개 Autosampler Programming  (For Old & New Versions), Set Number, Type, and Size of Samples: 3 단계, 이미지 3개 중 3개
      • 5. New screen shows: "SAMPLE EVERY __ PULSES." Press 20. Then push the “ENTER/PROGRAM” button.
      • 6. New screen will read: "MULTIPLEX SAMPLES?" Use arrow to select "NO". Then push the “ENTER/PROGRAM” button.
      • 7. New screen will read: "SAMPLE VOLUMES OF "____" ML". Press 1000. Then push the “ENTER/PROGRAM” button.
      댓글 쓰기
    4. Autosampler Programming  (For Old & New Versions), Starting Sampling: 4 단계, 이미지 3개 중 1개 Autosampler Programming  (For Old & New Versions), Starting Sampling: 4 단계, 이미지 3개 중 2개 Autosampler Programming  (For Old & New Versions), Starting Sampling: 4 단계, 이미지 3개 중 3개
      • 8. New screen will read: "ENTER START TIME?" Use arrow to select "NO". Then push the “ENTER/PROGRAM” button. New screen: "PROGRAMMING SEQUENCE COMPLETE...". Then screen will read: "PROGRAM HALTED".
      • 9. Push "START SAMPLING" button. Screen will read: "[START, RESUME] SAMPLING PROGRAM?" Push "ENTER/PROGRAM" button to "START". Then push "ENTER/PROGRAM" button again to "START SAMPLING AT BOTTLE 1".
      • 10. Then should see on screen: "START FLOW COUNT AT __:__" (time).
      • It will take some time before it starts sampling.
      • Eventually screen will show: " BOTTLE 1 AFTER 20 PULSES".
      댓글 쓰기
결승점
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Brooke Mason
회원 가입일: 05/29/19
2,958 평판
안내서 17개를 작성함
Open-Storm Open-Storm 회원
Community
14 회원들
안내서 75개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 12
지난 30일: 30
전체 시간: 505
