주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Axess SPBT1031 Battery Replacement
필요한 것
    1. Axess SPBT1031 Battery Replacement, Red Interface Plate: 1 단계, 이미지 1개 중 1개
      • Use a metal spudger to remove the mesh speaker covers (the side with the buttons) by wedging the narrow end into the center of the outer edge of the mesh, touching the red plate.
      댓글 쓰기
    2. Axess SPBT1031 Battery Replacement: 2 단계, 이미지 1개 중 1개
      • Remove the four 5 mm screws from the red panel under the mesh using a Phillips #1 screwdriver.
      댓글 쓰기
    3. Axess SPBT1031 Battery Replacement: 3 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      • If the screws are difficult to remove, use a pair of tweezers to twist and pick them out.
      댓글 쓰기
    4. Axess SPBT1031 Battery Replacement: 4 단계, 이미지 1개 중 1개
      • Separate the red interface plate from the black face plate by pulling them apart.
      댓글 쓰기
    1. Axess SPBT1031 Battery Replacement, Black Faceplate: 5 단계, 이미지 1개 중 1개
      • Look at the side of the speaker that has the red interface plate. Using a Phillips head PH1 screwdriver head, remove screws on the top and bottom of the black face plate. There will be one screw on top and one on the bottom.
      • Both screws are 0.55 cm in depth
      댓글 쓰기
    2. Axess SPBT1031 Battery Replacement: 6 단계, 이미지 1개 중 1개
      • Separate the black face plate from the tube by pulling them apart.
      • Be careful when pulling the wires apart or it will potentially damage the wires due to over stretching.
      댓글 쓰기
    1. Axess SPBT1031 Battery Replacement, Battery: 7 단계, 이미지 1개 중 1개
      • Look into the back of the black face plate and find the battery which is wrapped in green.
      • Battery is glued in place, remove by peeling it off.
      댓글 쓰기
    2. Axess SPBT1031 Battery Replacement: 8 단계, 이미지 1개 중 1개
      • Once the glue is removed, look into the red interface plate and then locate the bottom of the motherboard.
      • On the bottom of the motherboard, locate the black and red wire connected to the plastic red socket and remove the white insert from this socket.
      댓글 쓰기
    3. Axess SPBT1031 Battery Replacement: 9 단계, 이미지 1개 중 1개
      • Run the black and red wire in reverse through the hole in the black face plate to remove the battery.
      • Remove the battery from the black face plate.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Elvira Lou Evangelista
회원 가입일: 03/09/16
975 평판
안내서 6개를 작성함
UMass Dartmouth, Team 8-6, Botvin Spring 2016 UMass Dartmouth, Team 8-6, Botvin Spring 2016 회원
UMASSD-BOTVIN-S16S8G6
3 회원들
안내서 16개를 작성함
3가이드 댓글
ok, so is there any reason that I would not be able to put in a bigger battery for longer play? I realize I would have to mount it differently.
bartman777 - 답글 공유
why it is easily connect this blue tooth to cellphone done connecting to computer. Well not connect any of my 3 laptop computer ??????????????
htosee3791 - 답글 공유
What battery is used for the speaker?
De'Eric Dortch - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 9
지난 30일: 55
전체 시간: 9,405
