주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Axess TA2513-10WT Battery Replacement
필요한 것
    1. Axess TA2513-10WT Battery Replacement, Back Cover: 1 단계, 이미지 1개 중 1개
      • Lay the tablet down on a flat surface with the screen facing up, and the external camera facing upwards and closest to you.
      댓글 쓰기
    2. Axess TA2513-10WT Battery Replacement: 2 단계, 이미지 3개 중 1개 Axess TA2513-10WT Battery Replacement: 2 단계, 이미지 3개 중 2개 Axess TA2513-10WT Battery Replacement: 2 단계, 이미지 3개 중 3개
      • Insert the plastic opening tool in the space between the screen and the back cover above the volume buttons.
      • Slide the plastic opening tool gently along the sides.
      • If a small gap is not created between the screen and the back cover, pry gently upward at each of these latching points.
      댓글 쓰기
    3. Axess TA2513-10WT Battery Replacement: 3 단계, 이미지 1개 중 1개
      • Place the spudger in an open space to keep the back case from shutting while you continue to slide the opening tool.
      댓글 쓰기
    4. Axess TA2513-10WT Battery Replacement: 4 단계, 이미지 1개 중 1개
      • Remove the back cover with your hands once all points have been unlatched. It should separate completely from the screen that contains the battery and chip components.
      댓글 쓰기
    1. Axess TA2513-10WT Battery Replacement, Battery: 5 단계, 이미지 1개 중 1개
      • Shove the Spudger below the battery pack to remove any tape or adhesive residue.
      댓글 쓰기
    2. Axess TA2513-10WT Battery Replacement: 6 단계, 이미지 1개 중 1개
      • Lift the battery up with your hands to ensure complete detachment from the screen.
      댓글 쓰기
    3. Axess TA2513-10WT Battery Replacement: 7 단계, 이미지 1개 중 1개
      • Identify the red wire attached to the node labeled "B+" and the black wire attached to the node labeled "B-"
      댓글 쓰기
    4. Axess TA2513-10WT Battery Replacement: 8 단계, 이미지 1개 중 1개
      • Press the heated soldering iron down on the "B+" node while simultaneously tugging on the red wire.
      댓글 쓰기
    5. Axess TA2513-10WT Battery Replacement: 9 단계, 이미지 1개 중 1개
      • Remove the red wire from the node labeled "B+"
      댓글 쓰기
    6. Axess TA2513-10WT Battery Replacement: 10 단계, 이미지 1개 중 1개
      • Using the same process as the red wire, detach the black wire from the node labeled "B-".
      댓글 쓰기
    7. Axess TA2513-10WT Battery Replacement: 11 단계, 이미지 1개 중 1개
      • The battery should now be separated from both the screen and circuit board
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
2다른 기여자 명과 함께
Steven Kavanagh
회원 가입일: 03/24/15
301 평판
안내서 3개를 작성함
Baylor, Team 6-3, Shaver Spring 2015 Baylor, Team 6-3, Shaver Spring 2015 회원
BU-SHAVER-S15S6G3
3 회원들
안내서 30개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 8
지난 30일: 35
전체 시간: 677
