주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Azpen A701 Screen Replacement
필요한 것
    1. Azpen A701 Screen Replacement, General Disassembly Prerequisite Guide: 1 단계, 이미지 1개 중 1개
      • Remove the two 2cm screws on the bottom using the PH0 Phillips head screw driver.
      댓글 쓰기
    2. Azpen A701 Screen Replacement: 2 단계, 이미지 2개 중 1개 Azpen A701 Screen Replacement: 2 단계, 이미지 2개 중 2개
      • Pry open the back piece with the plastic spudger.
      • Remove the back piece from the device.
      • The back panel may be difficult to pry off, use gentle force.
      댓글 쓰기
    3. Azpen A701 Screen Replacement: 3 단계, 이미지 1개 중 1개
      • Disconnect speaker (which is attached by black and red wires) from back piece using plastic spudger.
      댓글 쓰기
    4. Azpen A701 Screen Replacement: 4 단계, 이미지 1개 중 1개
      • Gently pry the battery off of the device with the plastic spudger.
      • There is a large amount of glue holding the battery to the device.
      • Do not puncture the battery with the plastic spudger.
      댓글 쓰기
    1. Azpen A701 Screen Replacement, Screen: 5 단계, 이미지 3개 중 1개 Azpen A701 Screen Replacement, Screen: 5 단계, 이미지 3개 중 2개 Azpen A701 Screen Replacement, Screen: 5 단계, 이미지 3개 중 3개
      • Disconnect the two largest (of the three) ZIF cables by prying open the flap with a plastic spudger to gently remove them.
      댓글 쓰기
    2. Azpen A701 Screen Replacement: 6 단계, 이미지 1개 중 1개
      • Peel off the black tape from the corner of the motherboard (indicated by the blue surface of the device).
      댓글 쓰기
    3. Azpen A701 Screen Replacement: 7 단계, 이미지 3개 중 1개 Azpen A701 Screen Replacement: 7 단계, 이미지 3개 중 2개 Azpen A701 Screen Replacement: 7 단계, 이미지 3개 중 3개
      • Use a Phillips #000 screwdriver to remove the three screws that connect the motherboard to the front panel.
      • When removing the motherboard, be cautious of the gray wire connected from the motherboard to the actual device.
      댓글 쓰기
    4. Azpen A701 Screen Replacement: 8 단계, 이미지 1개 중 1개
      • Remove the motherboard and the battery and set aside.
      댓글 쓰기
    5. Azpen A701 Screen Replacement: 9 단계, 이미지 3개 중 1개 Azpen A701 Screen Replacement: 9 단계, 이미지 3개 중 2개 Azpen A701 Screen Replacement: 9 단계, 이미지 3개 중 3개
      • Remove the small orange tape attached with a gray wire from the top corner of the device. This is the antenna.
      • Use a plastic spudger around the silver lining within the device to pry the screen off.
      • The metal screen assembly is two pieces. When removing the screen, make sure to pry off both pieces at once.
      댓글 쓰기
    6. Azpen A701 Screen Replacement: 10 단계, 이미지 1개 중 1개
      • Replace the broken screen and reverse the steps to re-assemble the device.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Michael
회원 가입일: 03/11/15
568 평판
안내서 4개를 작성함
Colorado Springs, Team 2-1, Panko Spring 2015 Colorado Springs, Team 2-1, Panko Spring 2015 회원
UCCS-PANKO-S15S2G1
3 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 10
지난 30일: 32
전체 시간: 899
