주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
BEM Mojo 2 Speaker Replacement
필요한 것
    1. BEM Mojo 2 Speaker Replacement, Speaker Battery: 1 단계, 이미지 1개 중 1개
      • Pull back the rubber corners to uncover the bottom screws.
      • Continue this process for all four 10 mm screws.
      댓글 쓰기
    2. BEM Mojo 2 Speaker Replacement: 2 단계, 이미지 1개 중 1개
      • Use the J0 screwdriver to remove all four 10mm screws from the bottom of the speaker.
      • Caution: It is important when using the screwdriver to not use excessive force as this may strip the screw and can damage the speaker itself.
      댓글 쓰기
    3. BEM Mojo 2 Speaker Replacement: 3 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      • Remove the bottom cover of the speaker.
      • Caution: Be careful when removing the bottom cover of the speaker as there are wires that connect to the speaker itself that become exposed upon base removal.
      • Remove all of the wires from the speakers internal chip, utilizing the tweezers.
      • Caution: Be careful not to damage the chip.
      댓글 쓰기
    4. BEM Mojo 2 Speaker Replacement: 4 단계, 이미지 1개 중 1개
      • Remove the speakers battery from its metal base, utilizing the plastic opening tool.
      댓글 쓰기
    5. BEM Mojo 2 Speaker Replacement: 5 단계, 이미지 1개 중 1개
      • Remove the wires from the speakers battery using the tweezers or by gently removing them by lightly pinching.
      댓글 쓰기
    1. BEM Mojo 2 Speaker Replacement, Speaker Motherboard: 6 단계, 이미지 1개 중 1개
      • Use the J0 screwdriver to remove all four 10mm screws from the motherboard.
      댓글 쓰기
    2. BEM Mojo 2 Speaker Replacement: 7 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      • Remove the red/black wires in addition to the blue/white wires using the tweezers.
      댓글 쓰기
    3. BEM Mojo 2 Speaker Replacement: 8 단계, 이미지 1개 중 1개
      • Remove bus wire from the speaker's motherboard and lift the motherboard out of the speaker.
      댓글 쓰기
    1. BEM Mojo 2 Speaker Replacement, Speaker: 9 단계, 이미지 1개 중 1개
      • Remove any glue that is left over from previous parts that may be covering the screw holes or the speakers drive.
      댓글 쓰기
    2. BEM Mojo 2 Speaker Replacement: 10 단계, 이미지 2개 중 1개 BEM Mojo 2 Speaker Replacement: 10 단계, 이미지 2개 중 2개
      • Remove the speaker's four 10 mm base screws.
      댓글 쓰기
    3. BEM Mojo 2 Speaker Replacement: 11 단계, 이미지 2개 중 1개 BEM Mojo 2 Speaker Replacement: 11 단계, 이미지 2개 중 2개
      • Pry out the speaker's base using the metal Spuger. Use caution upon this step, it will require the use of force.
      • Remove the wire that will be placed in the speakers driver hole for access to the speaker.
      댓글 쓰기
    4. BEM Mojo 2 Speaker Replacement: 12 단계, 이미지 2개 중 1개 BEM Mojo 2 Speaker Replacement: 12 단계, 이미지 2개 중 2개
      • Remove the speaker's two 10 mm screws that are located in its base then take the driver out of the speaker.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
2다른 기여자 명과 함께
Rachel Iacoboni
회원 가입일: 01/30/18
618 평판
안내서 5개를 작성함
Baylor, Team S1-G1, Johnson Spring 2018 Baylor, Team S1-G1, Johnson Spring 2018 회원
BU-JOHNSON-S18S1G1
3 회원들
안내서 15개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 28
전체 시간: 784
