주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
BLU Life XL Volume Control Buttons Replacement
필요한 것
    1. BLU Life XL Volume Control Buttons Replacement, Volume Control Buttons: 1 단계, 이미지 3개 중 1개 BLU Life XL Volume Control Buttons Replacement, Volume Control Buttons: 1 단계, 이미지 3개 중 2개 BLU Life XL Volume Control Buttons Replacement, Volume Control Buttons: 1 단계, 이미지 3개 중 3개
      • Turn the device off by holding down the power button for up to 5 seconds and then tapping the "Power off" button on the screen.
      • Remove the rear cover using your hands at the lip on the device back cover. No tools required.
      • Remove the battery by lifting the lower edge of the battery up first.
      댓글 쓰기
    2. BLU Life XL Volume Control Buttons Replacement: 2 단계, 이미지 2개 중 1개 BLU Life XL Volume Control Buttons Replacement: 2 단계, 이미지 2개 중 2개
      • Remove the 12x3mm screws from the rear plate using the Phillips#000 screwdriver.
      댓글 쓰기
    3. BLU Life XL Volume Control Buttons Replacement: 3 단계, 이미지 2개 중 1개 BLU Life XL Volume Control Buttons Replacement: 3 단계, 이미지 2개 중 2개
      • Firmly press the prying tool into the gap between the front glass and rear plate. This gap is located on all sides of the phone.
      • Run the prying tool around the entire phone separating the rear plate from the frame.
      댓글 쓰기
    4. BLU Life XL Volume Control Buttons Replacement: 4 단계, 이미지 3개 중 1개 BLU Life XL Volume Control Buttons Replacement: 4 단계, 이미지 3개 중 2개 BLU Life XL Volume Control Buttons Replacement: 4 단계, 이미지 3개 중 3개
      • Gently remove the tape covering the volume control buttons. The tape is located near the top left of the cavity for the battery.
      • Replace the component and reapply the tape over the buttons.
      댓글 쓰기
결론
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
취소: 해당 안내서를 완성하지 않았습니다.
작성자
6다른 기여자 명과 함께
James Whitlow
회원 가입일: 02/14/18
342 평판
안내서 3개를 작성함
USF Tampa, Team S2-G5, Eyestone Spring 2018 USF Tampa, Team S2-G5, Eyestone Spring 2018 회원
USFT-EYESTONE-S18S2G5
3 회원들
안내서 35개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 15
지난 30일: 43
전체 시간: 670
