주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
BUSY Bar Disassembly
필요한 것
    1. BUSY Bar Disassembly, Remove the back cover: 1 단계, 이미지 3개 중 1개 BUSY Bar Disassembly, Remove the back cover: 1 단계, 이미지 3개 중 2개 BUSY Bar Disassembly, Remove the back cover: 1 단계, 이미지 3개 중 3개
      • The back cover is held in place by 8 clips.
      • Use a plastic card to release one of the clips near the center at the bottom of the back cover.
      • Gently release the remaining clips until the back cover comes off completely.
      댓글 쓰기
    2. BUSY Bar Disassembly, Remove the screws: 2 단계, 이미지 3개 중 1개 BUSY Bar Disassembly, Remove the screws: 2 단계, 이미지 3개 중 2개 BUSY Bar Disassembly, Remove the screws: 2 단계, 이미지 3개 중 3개
      • Use a PH1 Phillips screwdriver to remove 1 screw from the bottom and 4 screws from the back of the device.
      댓글 쓰기
    3. BUSY Bar Disassembly, Pull out the front display unit: 3 단계, 이미지 3개 중 1개 BUSY Bar Disassembly, Pull out the front display unit: 3 단계, 이미지 3개 중 2개 BUSY Bar Disassembly, Pull out the front display unit: 3 단계, 이미지 3개 중 3개
      • Do not pull the display unit too far out of the housing, as this may damage the display cable or connectors.
      • Do not disconnect the display cable. The battery must be disconnected first.
      • Use a plastic card to release the 2 latches on top of the front display.
      • Gently pull the front display unit out toward the right.
      댓글 쓰기
    4. BUSY Bar Disassembly, Remove the battery: 4 단계, 이미지 3개 중 1개 BUSY Bar Disassembly, Remove the battery: 4 단계, 이미지 3개 중 2개 BUSY Bar Disassembly, Remove the battery: 4 단계, 이미지 3개 중 3개
      • Gently move the battery to the left so you can access the connector.
      • Use tweezers or your fingertip to press the connector latch.
      • Pull the battery connector to disconnect it from the PCB.
      댓글 쓰기
    5. BUSY Bar Disassembly, Remove the front display unit: 5 단계, 이미지 3개 중 1개 BUSY Bar Disassembly, Remove the front display unit: 5 단계, 이미지 3개 중 2개 BUSY Bar Disassembly, Remove the front display unit: 5 단계, 이미지 3개 중 3개
      • Use a spudger to release the display cable connector latch.
      • Pull the cable in the direction indicated by the arrow.
      • Remove the front display unit.
      댓글 쓰기
    6. BUSY Bar Disassembly, Remove the battery pad: 6 단계, 이미지 2개 중 1개 BUSY Bar Disassembly, Remove the battery pad: 6 단계, 이미지 2개 중 2개
      • Use your fingers to lift and remove the silicone battery pad.
      댓글 쓰기
    7. BUSY Bar Disassembly, Disconnect the cable connecting the main and control PCBs: 7 단계, 이미지 3개 중 1개 BUSY Bar Disassembly, Disconnect the cable connecting the main and control PCBs: 7 단계, 이미지 3개 중 2개 BUSY Bar Disassembly, Disconnect the cable connecting the main and control PCBs: 7 단계, 이미지 3개 중 3개
      • Use tweezers to remove the yellow tape from the connector on the main PCB.
      • Use a halberd spudger to release the connector latch.
      • Use tweezers to disconnect the cable from the connector.
      댓글 쓰기
    8. BUSY Bar Disassembly, Disconnect the back display: 8 단계, 이미지 2개 중 1개 BUSY Bar Disassembly, Disconnect the back display: 8 단계, 이미지 2개 중 2개
      • Use a halberd spudger to release the latch on the display connector.
      • Gently press the flex cable with your finger and slide it out of the connector.
      댓글 쓰기
    9. BUSY Bar Disassembly, Remove the speaker: 9 단계, 이미지 3개 중 1개 BUSY Bar Disassembly, Remove the speaker: 9 단계, 이미지 3개 중 2개 BUSY Bar Disassembly, Remove the speaker: 9 단계, 이미지 3개 중 3개
      • Use a spudger to pry up the speaker connector and disconnect it.
      • Use tweezers to remove the speaker from the device housing.
      댓글 쓰기
    10. BUSY Bar Disassembly, Remove the control knobs: 10 단계, 이미지 3개 중 1개 BUSY Bar Disassembly, Remove the control knobs: 10 단계, 이미지 3개 중 2개 BUSY Bar Disassembly, Remove the control knobs: 10 단계, 이미지 3개 중 3개
      • Use a spudger or an opening tool to remove the scroll wheel, holding it with your other hand to prevent bending.
      • Using both hands, lift up the Start/Pause button knob to remove it.
      • Use a spudger or an opening tool to remove the mode selector cover.
      댓글 쓰기
    11. BUSY Bar Disassembly, Remove the main PCB: 11 단계, 이미지 3개 중 1개 BUSY Bar Disassembly, Remove the main PCB: 11 단계, 이미지 3개 중 2개 BUSY Bar Disassembly, Remove the main PCB: 11 단계, 이미지 3개 중 3개
      • Use a PH1 screwdriver to remove the 3 screws securing the PCB.
      • Carefully lift the PCB out of the device housing.
      댓글 쓰기
    12. BUSY Bar Disassembly, Remove the control unit: 12 단계, 이미지 3개 중 1개 BUSY Bar Disassembly, Remove the control unit: 12 단계, 이미지 3개 중 2개 BUSY Bar Disassembly, Remove the control unit: 12 단계, 이미지 3개 중 3개
      • Peel off the 2 black stickers from the control unit.
      • Use a spudger to release the 2 clips on the sides of the unit.
      • Use a halberd spudger to release the 2 clips closer to the center.
      • Remove the control unit from the device housing.
      댓글 쓰기
    13. BUSY Bar Disassembly, Remove the Back button cap and the light guides: 13 단계, 이미지 3개 중 1개 BUSY Bar Disassembly, Remove the Back button cap and the light guides: 13 단계, 이미지 3개 중 2개 BUSY Bar Disassembly, Remove the Back button cap and the light guides: 13 단계, 이미지 3개 중 3개
      • Remove the 2 white status indicator light guides by lifting them from the edge with your finger.
      • Use a spudger to release the latch securing the Back button cover.
      • Remove the Back button cover.
      댓글 쓰기
    14. BUSY Bar Disassembly, Remove the button stabilizer: 14 단계, 이미지 3개 중 1개 BUSY Bar Disassembly, Remove the button stabilizer: 14 단계, 이미지 3개 중 2개 BUSY Bar Disassembly, Remove the button stabilizer: 14 단계, 이미지 3개 중 3개
      • Remove the 3 screws from the bottom of the control unit.
      • Remove the stabilizer holder.
      댓글 쓰기
    15. BUSY Bar Disassembly, Remove the control PCB from the housing: 15 단계, 이미지 3개 중 1개 BUSY Bar Disassembly, Remove the control PCB from the housing: 15 단계, 이미지 3개 중 2개 BUSY Bar Disassembly, Remove the control PCB from the housing: 15 단계, 이미지 3개 중 3개
      • The control PCB is secured in the plastic housing by 5 latches.
      • Gently pull the PCB away from the plastic housing. You can pull by the scroll wheel or the mode selector.
      • Release the latches by bending them outward from the PCB using your finger, a spudger, or an opening tool.
      • Once all latches are released, remove the PCB from the housing.
      댓글 쓰기
    16. BUSY Bar Disassembly, Disconnect the cable from the control PCB: 16 단계, 이미지 2개 중 1개 BUSY Bar Disassembly, Disconnect the cable from the control PCB: 16 단계, 이미지 2개 중 2개
      • Use a spudger to carefully release the connector latch.
      • Remove the flex cable.
      댓글 쓰기
    17. BUSY Bar Disassembly, Remove the front display back cover: 17 단계, 이미지 3개 중 1개 BUSY Bar Disassembly, Remove the front display back cover: 17 단계, 이미지 3개 중 2개 BUSY Bar Disassembly, Remove the front display back cover: 17 단계, 이미지 3개 중 3개
      • The back cover of the front display unit is secured by 6 latches.
      • Use a spudger or a plastic card to carefully release the latches around the front display.
      • Remove the back cover of the front display unit.
      댓글 쓰기
    18. BUSY Bar Disassembly, Disassemble the front display unit: 18 단계, 이미지 3개 중 1개 BUSY Bar Disassembly, Disassemble the front display unit: 18 단계, 이미지 3개 중 2개 BUSY Bar Disassembly, Disassemble the front display unit: 18 단계, 이미지 3개 중 3개
      • The front display unit consists of a display PCB with LEDs and LED drivers, a plastic light separator, a matte light-diffusing film, and an outer tinted glass.
      • Remove the display PCB from the front display unit.
      • Remove the light separator.
      • Remove the light-diffusing film.
      댓글 쓰기
    19. BUSY Bar Disassembly, Remove the light guide and the cable from the display PCB: 19 단계, 이미지 3개 중 1개 BUSY Bar Disassembly, Remove the light guide and the cable from the display PCB: 19 단계, 이미지 3개 중 2개 BUSY Bar Disassembly, Remove the light guide and the cable from the display PCB: 19 단계, 이미지 3개 중 3개
      • Tilt the ambient light sensor light guide forward to disconnect it from the display PCB.
      • Use a spudger to release the flex cable connector latch.
      • Pull the flex cable in the direction indicated by the arrow to remove it.
      댓글 쓰기
    20. BUSY Bar Disassembly, Remove the monitor mount: 20 단계, 이미지 3개 중 1개 BUSY Bar Disassembly, Remove the monitor mount: 20 단계, 이미지 3개 중 2개 BUSY Bar Disassembly, Remove the monitor mount: 20 단계, 이미지 3개 중 3개
      • The 2 black polyurethane friction elements on the mount’s pivot create rotational resistance to hold the leg in intermediate positions.
      • Use a spudger to slide the 2 friction elements toward the center of the device. They move together with the short metal shafts and can then be removed from the housing.
      • Press the mount leg downward toward the center of the device (following the orange arrow).
      • At the same time push the mount leg sideways (following the red arrow) to release it from the slot.
      • Repeat these steps for the opposite side of the leg to remove it.
      댓글 쓰기
    21. BUSY Bar Disassembly, Device fully disassembled: 21 단계, 이미지 1개 중 1개
      • The device is now fully disassembled. The picture shows all its components.
      댓글 쓰기
결론
To reassemble the device, follow these steps in reverse order.
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Flipper Devices
회원 가입일: 06/29/22
1,099 평판
안내서 3개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 55
지난 30일: 186
전체 시간: 734
