주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Back of Bookshelf Replacement
필요한 것
    1. Back of Bookshelf Replacement, Back of Bookshelf: 1 단계, 이미지 1개 중 1개
      • Gather all pieces of the bookshelf if it fell apart or the shelf itself is still together.
      • You will need two people to complete this project.
      댓글 쓰기
    2. Back of Bookshelf Replacement: 2 단계, 이미지 3개 중 1개 Back of Bookshelf Replacement: 2 단계, 이미지 3개 중 2개 Back of Bookshelf Replacement: 2 단계, 이미지 3개 중 3개
      • You will need to put the bookshelf back together by holding the sides together.
      • Drill new holes to insert new screws to reinforce the shelf. Use a 1/8 inch drill bit.
      • Put screws into the freshly made holes with 1/8 by 1 inch wood screws to bring it together.
      댓글 쓰기
    3. Back of Bookshelf Replacement: 3 단계, 이미지 3개 중 1개 Back of Bookshelf Replacement: 3 단계, 이미지 3개 중 2개 Back of Bookshelf Replacement: 3 단계, 이미지 3개 중 3개
      • Now that the base of the bookshelf is back together, we will need to measure out the size of board needed for the new backing.
      • Use the measuring tape and the square ruler to measure out the specific size you need. Use a pencil to draw the lines out so you can saw the piece out with precision.
      • Use the jig saw to cut the piece of plywood out following the lines you just drew.
      댓글 쓰기
    4. Back of Bookshelf Replacement: 4 단계, 이미지 3개 중 1개 Back of Bookshelf Replacement: 4 단계, 이미지 3개 중 2개 Back of Bookshelf Replacement: 4 단계, 이미지 3개 중 3개
      • Line your new piece of plywood that you just cut, up with the back of the bookshelf.
      • Make sure that the corners are lined up so that as you hammer in the nails it stays lined up and even.
      댓글 쓰기
    5. Back of Bookshelf Replacement: 5 단계, 이미지 2개 중 1개 Back of Bookshelf Replacement: 5 단계, 이미지 2개 중 2개
      • Start from the top and work your way down each side when putting the nails in so the board doesn't bow.
      • Use 2d penny nails and hammer them in along all four sides.
      • Five nails on each of the four sides is all you will need.
      댓글 쓰기
    6. Back of Bookshelf Replacement: 6 단계, 이미지 2개 중 1개 Back of Bookshelf Replacement: 6 단계, 이미지 2개 중 2개
      • The shelf has its new plywood backing, so you can stand it up and you will feel the immediate difference in the sturdiness of your new shelf.
      • Place the shelf in the room of your choosing and place your books on it, knowing that it will not fall apart.
      댓글 쓰기
결승점
취소: 해당 안내서를 완성하지 않았습니다.
다른 5명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Melissa Miller
회원 가입일: 03/07/19
268 평판
안내서 1개를 작성함
1가이드 댓글
How to build a secretive chair
Imoh - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 7
지난 7일: 32
지난 30일: 167
전체 시간: 13,479
