주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Backbone One Face Buttons Replacement
필요한 것
  1. Backbone One Face Buttons Replacement, Remove the screws: 1 단계, 이미지 1개 중 1개
    • Use a Phillips screwdriver to remove the four 5.9 mm-long screws.
    댓글 쓰기
  2. Backbone One Face Buttons Replacement, Rotate the upper part: 2 단계, 이미지 3개 중 1개 Backbone One Face Buttons Replacement, Rotate the upper part: 2 단계, 이미지 3개 중 2개 Backbone One Face Buttons Replacement, Rotate the upper part: 2 단계, 이미지 3개 중 3개
    • Lift up the upper cover of the controller.
    • Swing the upper cover over and place it on the controller case.
    • Make sure that the interconnecting cable has no tension.
    댓글 쓰기
  3. Backbone One Face Buttons Replacement, Remove the protective tape: 3 단계, 이미지 3개 중 1개 Backbone One Face Buttons Replacement, Remove the protective tape: 3 단계, 이미지 3개 중 2개 Backbone One Face Buttons Replacement, Remove the protective tape: 3 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Use a pair of tweezers to remove the yellow protective tape which is placed over the interconnect cable and the connector.
    댓글 쓰기
  4. Backbone One Face Buttons Replacement, Open the interconnect cable ZIF connector: 4 단계, 이미지 3개 중 1개 Backbone One Face Buttons Replacement, Open the interconnect cable ZIF connector: 4 단계, 이미지 3개 중 2개 Backbone One Face Buttons Replacement, Open the interconnect cable ZIF connector: 4 단계, 이미지 3개 중 3개
    • Use the tip of an opening pick to open the gray flap of the interconnect cable ZIF connector by pushing it upwards.
    댓글 쓰기
  5. Backbone One Face Buttons Replacement, Disconnect the interconnect cable: 5 단계, 이미지 2개 중 1개 Backbone One Face Buttons Replacement, Disconnect the interconnect cable: 5 단계, 이미지 2개 중 2개
    • Disconnect the cable by pulling it straight out the ZIF connector.
    댓글 쓰기
  6. Backbone One Face Buttons Replacement, Disconnect the phone connector cables: 6 단계, 이미지 3개 중 1개 Backbone One Face Buttons Replacement, Disconnect the phone connector cables: 6 단계, 이미지 3개 중 2개 Backbone One Face Buttons Replacement, Disconnect the phone connector cables: 6 단계, 이미지 3개 중 3개
    • Use a pair of tweezers to disconnect the phone connector cables out from their sockets.
    댓글 쓰기
  7. Backbone One Face Buttons Replacement, Separate the upper case: 7 단계, 이미지 1개 중 1개
    • Separate the the upper case of the left controller handle.
    댓글 쓰기
  8. Backbone One Face Buttons Replacement, Remove the screws: 8 단계, 이미지 1개 중 1개
    • Use a Phillips screwdriver to remove the three 5.9 mm-long screws.
    댓글 쓰기
  9. Backbone One Face Buttons Replacement, Remove the trigger: 9 단계, 이미지 2개 중 1개 Backbone One Face Buttons Replacement, Remove the trigger: 9 단계, 이미지 2개 중 2개
    • Remove the trigger.
    댓글 쓰기
  10. Backbone One Face Buttons Replacement, Remove the bumper: 10 단계, 이미지 2개 중 1개 Backbone One Face Buttons Replacement, Remove the bumper: 10 단계, 이미지 2개 중 2개
    • Remove the bumper.
    댓글 쓰기
  11. Backbone One Face Buttons Replacement, Remove the screws: 11 단계, 이미지 1개 중 1개
    • Use a Phillips screwdriver to remove the two 3.9 mm-long screws.
    댓글 쓰기
  12. Backbone One Face Buttons Replacement, Remove the mainboard: 12 단계, 이미지 3개 중 1개 Backbone One Face Buttons Replacement, Remove the mainboard: 12 단계, 이미지 3개 중 2개 Backbone One Face Buttons Replacement, Remove the mainboard: 12 단계, 이미지 3개 중 3개
    • Remove the mainboard.
    댓글 쓰기
  13. Backbone One Face Buttons Replacement, Remove the rubber cover: 13 단계, 이미지 3개 중 1개 Backbone One Face Buttons Replacement, Remove the rubber cover: 13 단계, 이미지 3개 중 2개 Backbone One Face Buttons Replacement, Remove the rubber cover: 13 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Use a pair of blunt nose tweezers to remove the rubber cover which is placed over the face buttons.
    댓글 쓰기
  14. Backbone One Face Buttons Replacement, Remove the face buttons: 14 단계, 이미지 3개 중 1개 Backbone One Face Buttons Replacement, Remove the face buttons: 14 단계, 이미지 3개 중 2개 Backbone One Face Buttons Replacement, Remove the face buttons: 14 단계, 이미지 3개 중 3개
    • Use a pair of tweezers to remove the face buttons.
    댓글 쓰기
결론
Repair didn’t go as planned? Ask our Answers community for help.
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Adriana Zwink
회원 가입일: 12/18/19
67,642 평판
안내서 167개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 28,226개를 작성함
1가이드 댓글
is there any way to do this without taking apart the entire controller?
Robert - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 22
지난 30일: 78
전체 시간: 3,505
