주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Backpack Base Replacement
필요한 것
    1. Backpack Base Replacement, Base: 1 단계, 이미지 2개 중 1개 Backpack Base Replacement, Base: 1 단계, 이미지 2개 중 2개
      • Turn the backpack inside out.
      댓글 쓰기
    2. Backpack Base Replacement: 2 단계, 이미지 1개 중 1개
      • Seam rip the binding along the bottom rectangle of the backpack.
      • Discard the ripped panel of burlap.
      • Make sure to set aside the lining fabric before discarding the burlap.
      댓글 쓰기
    3. Backpack Base Replacement: 3 단계, 이미지 3개 중 1개 Backpack Base Replacement: 3 단계, 이미지 3개 중 2개 Backpack Base Replacement: 3 단계, 이미지 3개 중 3개
      • Iron the base panel of the polyester lining fabric.
      • Place the lining fabric on top of the desired fabric.
      • Using a ruler and rotary cutter, cut an identical rectangle.
      • Carefully round the corners of your desired fabric rectangle to match the shape of the liner.
      • Use caution when ironing the base panel.
      댓글 쓰기
    4. Backpack Base Replacement: 4 단계, 이미지 3개 중 1개 Backpack Base Replacement: 4 단계, 이미지 3개 중 2개 Backpack Base Replacement: 4 단계, 이미지 3개 중 3개
      • Pin the liner and new fabric panel together, so that the 'right sides' of the fabric are facing outwards.
      • Set your machine to the longest stitch length (usually 5 mm), and the loosest thread tension.
      • Not every machine will allow you to adjust the thread tension. If yours allows you to adjust it, set it to zero.
      • Sew the layers together with a 1/4" seam allowance.
      댓글 쓰기
    5. Backpack Base Replacement: 5 단계, 이미지 3개 중 1개 Backpack Base Replacement: 5 단계, 이미지 3개 중 2개 Backpack Base Replacement: 5 단계, 이미지 3개 중 3개
      • Pin the lining and new fabric base so that it is centered on the thick side of the backpack.
      • Using a zipper foot, sew the new fabric base and liner to the thick side of the backpack.
      • Be careful to align the corners of the base to the corners of the backpack.
      댓글 쓰기
    6. Backpack Base Replacement: 6 단계, 이미지 3개 중 1개 Backpack Base Replacement: 6 단계, 이미지 3개 중 2개 Backpack Base Replacement: 6 단계, 이미지 3개 중 3개
      • Make note of how much larger the fabric base is in comparison to the remaining 3 sides of the backpack.
      • Using a contrasting-colored thread, hand-sew along the corners of the base fabric.
      • Tighten the contrasting threads to bunch up the corners until they fit snug into the corners of the backpack.
      • Pin the remaining 3 sides of the base with to the 3 sides of the backpack.
      댓글 쓰기
    7. Backpack Base Replacement: 7 단계, 이미지 3개 중 1개 Backpack Base Replacement: 7 단계, 이미지 3개 중 2개 Backpack Base Replacement: 7 단계, 이미지 3개 중 3개
      • Sew along the remaining three sides.
      • Be extra careful around the corners to avoid any hard creases or folds.
      • Seam-rip the contrasting color thread.
      • Trim down any fabric that exceeds 1/4" seam allowance, particularly around the corners.
      댓글 쓰기
    8. Backpack Base Replacement: 8 단계, 이미지 2개 중 1개 Backpack Base Replacement: 8 단계, 이미지 2개 중 2개
      • Turn the backpack right side out.
      • Look along the new seam for any of the stitches that hold the lining and base fabric together, and remove them.
      • Pin the binding around the bottom seam, so that it sandwiches the seam allowance.
      • Allow one end of the binding to remain loose.
      댓글 쓰기
    9. Backpack Base Replacement: 9 단계, 이미지 3개 중 1개 Backpack Base Replacement: 9 단계, 이미지 3개 중 2개 Backpack Base Replacement: 9 단계, 이미지 3개 중 3개
      • Starting with the pinned end of the binding, carefully sew about 1/10" away from the end of the binding.
      • When you reach the loose end of the binding, connect the end that you already sewed with the loose end.
      • Sew both ends together.
      댓글 쓰기
    10. Backpack Base Replacement: 10 단계, 이미지 3개 중 1개 Backpack Base Replacement: 10 단계, 이미지 3개 중 2개 Backpack Base Replacement: 10 단계, 이미지 3개 중 3개
      • Check the inside and out for any flaws or hard creases.
      • Enjoy your newly repaired backpack!
      댓글 쓰기
결승점
취소: 해당 안내서를 완성하지 않았습니다.
작성자
2다른 기여자 명과 함께
Sheen Patel
회원 가입일: 02/21/23
181 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 9
지난 30일: 52
전체 시간: 2,258
