주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Backyard Fence Post Replacement
필요한 것
    1. Backyard Fence Post Replacement, Backyard fence post: 1 단계, 이미지 2개 중 1개 Backyard Fence Post Replacement, Backyard fence post: 1 단계, 이미지 2개 중 2개
      • Measure the damaged post to purchase the replacement.
      • Take photo of post and take note of where the boards are connected.
      • Clear out work area of any clutter or hazards.
      댓글 쓰기
    2. Backyard Fence Post Replacement: 2 단계, 이미지 1개 중 1개
      • Use a shovel to dig a deep hole around the post until you expose the concrete below the soil.
      • If necessary you can attempt to break off the top of the post to allow for more room. The pickaxe can be a good tool for this.
      • Make sure to keep the excess dirt in a small pile, as this is what you need to fill the hole.
      댓글 쓰기
    3. Backyard Fence Post Replacement: 3 단계, 이미지 1개 중 1개
      • Excavate the dirt surrounding the concrete to allow more room for the pickaxe.
      • Use a pickaxe to break up the concrete into smaller chunks and remove them from the hole.
      댓글 쓰기
    4. Backyard Fence Post Replacement: 4 단계, 이미지 1개 중 1개
      • Carefully lift the post out of the hole.
      • Leave the hole as it is, so you don't have to do additional digging.
      댓글 쓰기
    5. Backyard Fence Post Replacement: 5 단계, 이미지 1개 중 1개
      • Insert the new post into the hole left by the damaged one.
      • If the post is loose, place the larger concrete chunks to support the post while you prepare for the next step.
      댓글 쓰기
    6. Backyard Fence Post Replacement: 6 단계, 이미지 1개 중 1개
      • Fill in the hole about halfway around the post, leaving 6-10 inches below the surface to allow room for the concrete.
      댓글 쓰기
    7. Backyard Fence Post Replacement: 7 단계, 이미지 2개 중 1개 Backyard Fence Post Replacement: 7 단계, 이미지 2개 중 2개
      • Use the drill and screws to secure the fence support beams to the new fence posts.
      • Use 2-3 screws per support to ensure that the fence remains sturdy.
      댓글 쓰기
    8. Backyard Fence Post Replacement: 8 단계, 이미지 1개 중 1개
      • Pour 3-4 inches of cement into the hole surrounding the new post.
      • Following the directions on the cement, pour room temperature water over the powder until it is fully saturated and some water remains on top.
      • Wait 2-3 hours for cement to set.
      댓글 쓰기
    9. Backyard Fence Post Replacement: 9 단계, 이미지 1개 중 1개
      • Cover the cement with the remaining dirt once it has finished setting and pat it down.
      댓글 쓰기
    10. Backyard Fence Post Replacement: 10 단계, 이미지 2개 중 1개 Backyard Fence Post Replacement: 10 단계, 이미지 2개 중 2개
      • Line up boards with existing boards so they are flush with the ground.
      • Use the drill and screws to secure the boards to the the post.
      • Use 2 screws at both the top and bottom of the boards to distribute weight.
      • Clean up the work area and check for lost screws.
      댓글 쓰기
결론
By the end of this guide the post should be installed and secure.
취소: 해당 안내서를 완성하지 않았습니다.
작성자
1다른 기여자 명과 함께
kaitlyn
회원 가입일: 08/27/25
189 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 10
지난 30일: 38
전체 시간: 384
