주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Basic Maintenance
필요한 것
    1. Basic Maintenance, Locating the side panel: 1 단계, 이미지 2개 중 1개 Basic Maintenance, Locating the side panel: 1 단계, 이미지 2개 중 2개
      • First, locate the side panel on the far left side of your board.
      • Then, flip your board upside down.
      • Make sure your console is resting on a towel or soft surface, as hard jolts or bumps can cause damage to your board.
      댓글 쓰기
    2. Basic Maintenance, Removing the bracket: 2 단계, 이미지 2개 중 1개 Basic Maintenance, Removing the bracket: 2 단계, 이미지 2개 중 2개
      • Now, use your Phillips-head screwdriver to unscrew the two screws holding the bracket on.
      • Then flip your board over and do the same on the other side to remove the second bracket.
      댓글 쓰기
    3. Basic Maintenance, Loosening the panel screws: 3 단계, 이미지 1개 중 1개
      • Now, locate the three screws at the bottom of the back panel and loosen them approximately two full turns.
      • Make sure to keep screws separate! Always label and separate different screws to avoid confusion when we reassemble the board.
      댓글 쓰기
    4. Basic Maintenance, Remove the metal pieces: 4 단계, 이미지 1개 중 1개
      • Now flip your board over again so it is right-side-up.
      • Then, remove the seven screws holding the metal piece on with the same screwdriver. There is one screw to the far right of the piece that I could not fit into the photo.
      댓글 쓰기
    5. Basic Maintenance, Pull the top off: 5 단계, 이미지 2개 중 1개 Basic Maintenance, Pull the top off: 5 단계, 이미지 2개 중 2개
      • Now, put your hand on the back of the board and lift up and away from the base of the console. Be careful of any wires!
      • Set the top panel next to the base to avoid wires getting tangled and broken.
      댓글 쓰기
    6. Basic Maintenance, The inside components: 6 단계, 이미지 2개 중 1개 Basic Maintenance, The inside components: 6 단계, 이미지 2개 중 2개
      • You might notice that a lot of the components inside the lighting board look similar to those of a desktop computer. The power supply, hard drive, RAM, CPU, and cooling system are all in the base of the board.
      • If you have a compressed air can or blower, use that to clean the main components, especially around the CPU and heatsinks, as these can get clogged with dust and debris. If you don't have one of these tools, use a DRY paper towel or tissue to gently wipe down the components.
      댓글 쓰기
    7. Basic Maintenance, Re-seating the RAM: 7 단계, 이미지 2개 중 1개 Basic Maintenance, Re-seating the RAM: 7 단계, 이미지 2개 중 2개
      • RAM is good to re-seat every so often, as it helps to maintain clean ports and fast memory speeds.
      • To remove the RAM, press down on the two clips on either side of the stick, then pull up on the RAM to remove it.
      • Once you remove it, you can take your air blower and gently blow off any dust on the connectors and memory cards.
      댓글 쓰기
      • Now reverse these steps to reassemble your ETC Ion 1000!
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
someperson
회원 가입일: 02/11/26
953 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 19
전체 시간: 94
