주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Basis Peak Battery Replacement
필요한 것
    1. Basis Peak Battery Replacement, Frame: 1 단계, 이미지 1개 중 1개
      • Flip the watch over and orient it such that the buckle is away from you and the back panel is revealed.
      • Maintain this orientation to follow the guide.
      댓글 쓰기
    2. Basis Peak Battery Replacement: 2 단계, 이미지 2개 중 1개 Basis Peak Battery Replacement: 2 단계, 이미지 2개 중 2개
      • Remove the four base screws using a size 2 TORX screwdriver to separate the back plate from the frame.
      댓글 쓰기
    3. Basis Peak Battery Replacement: 3 단계, 이미지 1개 중 1개
      • Disconnect the ribbon cable on the left side of the motherboard by using a spudger.
      댓글 쓰기
    4. Basis Peak Battery Replacement: 4 단계, 이미지 1개 중 1개
      • Use a spudger and apply pressure to the white plastic wall to the right of the motherboard. Use this to lever the electronics out of the frame.
      • The clips have small lips that you can put the spudger under to get more leverage.
      • Using any of the metal to pry out the electronics may damage some of the wiring. It is crucial to only press on the plastic.
      댓글 쓰기
    1. Basis Peak Battery Replacement, Motherboard: 5 단계, 이미지 1개 중 1개
      • Remove the right side ribbon cable by pulling it off with your fingers.
      댓글 쓰기
    2. Basis Peak Battery Replacement: 6 단계, 이미지 1개 중 1개
      • Use the spudger tool to poke out the exposed motherboard section as seen in the photo.
      • As always be careful when disconnecting the cables or batteries.
      댓글 쓰기
    3. Basis Peak Battery Replacement: 7 단계, 이미지 1개 중 1개
      • Put a nylon spudger underneath the battery's press-fit connector and lift up to free the ribbon cable and motherboard.
      댓글 쓰기
    1. Basis Peak Battery Replacement, Battery: 8 단계, 이미지 1개 중 1개
      • Grip the battery with your fingers and remove it from the plastic.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
2다른 기여자 명과 함께
Dominic Calcasola
회원 가입일: 03/26/17
101 평판
안내서 1개를 작성함
UMass Dartmouth, Team S4-G4, Julie Spring 2017 UMass Dartmouth, Team S4-G4, Julie Spring 2017 회원
UMASSD-JULIE-S17S4G4
4 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 19
전체 시간: 690
