주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Battery Disconnect
필요한 것
  1. Battery Disconnect, SIM Card: 1 단계, 이미지 2개 중 1개 Battery Disconnect, SIM Card: 1 단계, 이미지 2개 중 2개
    • Insert a SIM card eject tool, bit, or a straightened paperclip into the small hole in the SIM card tray.
    • Press to eject the tray.
    댓글 쓰기
  2. Battery Disconnect: 2 단계, 이미지 2개 중 1개 Battery Disconnect: 2 단계, 이미지 2개 중 2개
    • Remove the SIM card tray from the phone.
    • The SIM card(s) and SD card will fall out of the tray easily.
    • When reinserting the tray, ensure the SIM card and SD card are in the correct slots and oriented correctly.
    • For dual-SIM versions of this phone, there may be two SIM cards. Ensure the SIM cards are placed in the slots corresponding to the correct phone lines.
    댓글 쓰기
  3. Battery Disconnect, Back Cover: 3 단계, 이미지 1개 중 1개
    • The back cover is held in place by plastic clips.
    • Insert an opening pick between the screen and the back cover on the bottom of the phone where the charging port is located.
    댓글 쓰기
  4. Battery Disconnect: 4 단계, 이미지 1개 중 1개
    • Slide the opening pick to the bottom left corner to release the clips.
    댓글 쓰기
  5. Battery Disconnect: 5 단계, 이미지 1개 중 1개
    • Slide the opening pick along the left edge to the top left corner of the phone, to release the clips.
    댓글 쓰기
  6. Battery Disconnect: 6 단계, 이미지 1개 중 1개
    • Slide the opening pick from the top left corner to the top right corner to release the plastic clips.
    댓글 쓰기
  7. Battery Disconnect: 7 단계, 이미지 1개 중 1개
    • Slide the opening pick from the top right corner to the bottom right corner to release the remaining clips.
    댓글 쓰기
  8. Battery Disconnect: 8 단계, 이미지 1개 중 1개
    • Remove the back cover.
    댓글 쓰기
  9. Battery Disconnect, Motherboard Cover: 9 단계, 이미지 1개 중 1개
    • Remove screws from the motherboard antenna cover.
    • 3 Phillips #00, 3mm length.
    댓글 쓰기
  10. Battery Disconnect: 10 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Use the tip of a spudger or tweezers to remove the antenna cover.
    댓글 쓰기
  11. Battery Disconnect: 11 단계, 이미지 1개 중 1개
    • Remove screws from the motherboard cover.
    댓글 쓰기
  12. Battery Disconnect: 12 단계, 이미지 1개 중 1개
    • Use the tip of a spudger or tweezers to remove the motherboard cover.
    댓글 쓰기
  13. Battery Disconnect, Battery Disconnect: 13 단계, 이미지 2개 중 1개 Battery Disconnect, Battery Disconnect: 13 단계, 이미지 2개 중 2개
    • Use a spudger to disconnect the battery by prying the connector straight up from its socket.
    댓글 쓰기
  14. Battery Disconnect: 14 단계, 이미지 1개 중 1개
    • Gently flex the battery connector away from its socket.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 7명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Thomas Boland
회원 가입일: 09/29/20
1,932 평판
안내서 5개를 작성함
2가이드 댓글
Do I need to heat up the screen of my phone to make it easier for me to get the back cover off of my phone?
Pifase - 답글 공유
no, it just clips on, there's no adhesive
Ely Wickander - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 9
지난 30일: 54
전체 시간: 3,168
