소개
This guide will explain how to remove and replace the speakers on the Beats Pill 1.0. This will require almost complete disassembly of the device.
부품
지정된 부품이 없습니다.
Using the spudger, create space between the speaker covers and then remove.
On the underside of the device, remove the rubber stand with the BeatsPill logo on it.
Using a ESD-safe Philips #0 Screwdriver, remove the four screws that were underneath the rubber stand.
Remove the two Philips #0 screws with the ESD-safe screwdriver.
Slowly remove the center band and 2 clip rings until the adhesive separates.
Using the spudger, starting in the middle, pry the device apart along it’s seam as circled in red.
Open the device to separate the two main bodies of the device. The device should look as picture number 3.
Remove the speaker wire(yellow, red, black, white) from the mother board.
Using a PH0 or PH00 bit head unscrew the four (diameter = .072 in, length = .239 in) screws holding the band holding the battery in place.
Using a soldering iron attach the battery to the new motherboard with the red wire connecting to the 0.2 volts (+) and black wire connecting to the ground (-). Please refer to our soldering guide for more information.
다른 4명이 해당 안내서를 완성하였습니다.
댓글 12개
Hi everyone!
Does anyone know from where I can buy a motherboard for a Beats Pill??
How do I unplug the cord from the battery? I don't want to damage any cords or plugs, Thanks!
Owen Gerke - 답글
Same as akon4konvicted: "Does anyone know from where I can buy a motherboard for a Beats Pill??
While trying to repair I snapped that yellow part with the thin copper running through it, I tried to repair this with superglue but I don't think it worked. Not sure what the part does but is it still safe to use?
