주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Beats Pill XL 'b' Button Replacement
필요한 것
    1. Beats Pill XL 'b' Button Replacement, Case: 1 단계, 이미지 2개 중 1개 Beats Pill XL 'b' Button Replacement, Case: 1 단계, 이미지 2개 중 2개
      • Using a plastic opening tool, pry the casing from the rest of the device.
      • Pry all the way around the edge and then pull apart.
      • It should be relatively easy, to pull apart. Don't be afraid to apply a necessary force.
      댓글 쓰기
    2. Beats Pill XL 'b' Button Replacement: 2 단계, 이미지 1개 중 1개
      • Using your thumb, remove the 8 rubber plugs in order to get to the screws.
      • Simply rub them towards the speakers and they will slide out enough to grip the edge and pull them out.
      • In the picture provided, we labeled four of them on one side of the Beats Pill XL. The other four are symmetrical to these four on the other side of the device.
      댓글 쓰기
    3. Beats Pill XL 'b' Button Replacement: 3 단계, 이미지 2개 중 1개 Beats Pill XL 'b' Button Replacement: 3 단계, 이미지 2개 중 2개
      • Using a Phillips #2 screwdriver, remove the 8 (10mm maxi-loc Phillips #2) screws that hold the casing together.
      댓글 쓰기
    4. Beats Pill XL 'b' Button Replacement: 4 단계, 이미지 2개 중 1개 Beats Pill XL 'b' Button Replacement: 4 단계, 이미지 2개 중 2개
      • Pull apart the front casing from the back casing, slowly. Try to avoid any tension on any of the connected cables.
      • Separate at a slow constant force to avoid damage to the ribbon cables.
      댓글 쓰기
    5. Beats Pill XL 'b' Button Replacement: 5 단계, 이미지 2개 중 1개 Beats Pill XL 'b' Button Replacement: 5 단계, 이미지 2개 중 2개
      • Gently pull on the plastic tab at the base of the ribbon cable to remove it from the motherboard.
      • Never pull the cables by the cord, as this could cause damage to the cables and/or motherboard. Always disconnect the cables from the base by the motherboard.
      댓글 쓰기
    6. Beats Pill XL 'b' Button Replacement: 6 단계, 이미지 2개 중 1개 Beats Pill XL 'b' Button Replacement: 6 단계, 이미지 2개 중 2개
      • Using your thumb and index finger, pull upwards on the base of the the power cable to remove it from the motherboard.
      • Even though there are two batteries, there is only one cable connecting the two to the motherboard.
      댓글 쓰기
    1. Beats Pill XL 'b' Button Replacement, 'b' Button: 7 단계, 이미지 2개 중 1개 Beats Pill XL 'b' Button Replacement, 'b' Button: 7 단계, 이미지 2개 중 2개
      • Remove the speaker cables by using gentle constant force with fingers.
      댓글 쓰기
    2. Beats Pill XL 'b' Button Replacement: 8 단계, 이미지 1개 중 1개
      • Separate the front case with the speakers and 'b' button from the mother board housing.
      댓글 쓰기
    3. Beats Pill XL 'b' Button Replacement: 9 단계, 이미지 2개 중 1개 Beats Pill XL 'b' Button Replacement: 9 단계, 이미지 2개 중 2개
      • Using a Phillips #2 screwdriver, remove the 4 (8mm pan head Phillips #2) screws using a Philips #02 screwdriver.
      댓글 쓰기
    4. Beats Pill XL 'b' Button Replacement: 10 단계, 이미지 2개 중 1개 Beats Pill XL 'b' Button Replacement: 10 단계, 이미지 2개 중 2개
      • Using a plastic opening tool pry the 'b' button housing from the casing.
      • Note: Little to no resistance is met when prying the housing from the casing.
      • Use fingers to completely remove the 'b' button housing from the casing.
      댓글 쓰기
    5. Beats Pill XL 'b' Button Replacement: 11 단계, 이미지 1개 중 1개
      • Use fingers to remove 'b' button from circuit board.
      • Note: Circuit board and housing should be replaced as an assembly.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Alejandro Velez
회원 가입일: 03/11/15
125 평판
안내서 1개를 작성함
Colorado Springs, Team 9-2, Panko Spring 2015 Colorado Springs, Team 9-2, Panko Spring 2015 회원
UCCS-PANKO-S15S9G2
3 회원들
안내서 22개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 13
지난 30일: 49
전체 시간: 4,436
