주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Beats Studio 3 Headband Replacement
필요한 것
    1. Beats Studio 3 Headband Replacement, Headband: 1 단계, 이미지 1개 중 1개
      • Slide the headband down to reveal the the screws
      • Unscrew both screws from each side of the Headphones.
      댓글 쓰기
    2. Beats Studio 3 Headband Replacement: 2 단계, 이미지 3개 중 1개 Beats Studio 3 Headband Replacement: 2 단계, 이미지 3개 중 2개 Beats Studio 3 Headband Replacement: 2 단계, 이미지 3개 중 3개
      • Remove the foam pad
      • Remove the cushion pad
      • Remove the broken headband.
      • Keep the cushion pad and foam pad to the side.
      • When removing the cushion pad, you will have to use some force and will make a snapping noise, which is normal.
      댓글 쓰기
    3. Beats Studio 3 Headband Replacement: 3 단계, 이미지 2개 중 1개 Beats Studio 3 Headband Replacement: 3 단계, 이미지 2개 중 2개
      • Get the new headband and snap back the cushion pad together.
      • Put back the foam pad together.
      댓글 쓰기
    4. Beats Studio 3 Headband Replacement: 4 단계, 이미지 2개 중 1개 Beats Studio 3 Headband Replacement: 4 단계, 이미지 2개 중 2개
      • Screw in both screws on each side of the headphones.
      댓글 쓰기
결론
  1. locate screws and unscrew
  2. remove cushion, foam, and broken headband
  3. remove any broken plastic inside the clasps
  4. get the new headband and place it on the headphones; make sure the letter B is on the left and the S on the right of the headphones
  5. place foam and cushion with the headband. It will make a snapping noise if done correctly
  6. screw in the screws
취소: 해당 안내서를 완성하지 않았습니다.
다른 10명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Ivan
회원 가입일: 08/22/23
379 평판
안내서 1개를 작성함
CSU Los Angeles, Team 3-3, Briggs Fall 2023 CSU Los Angeles, Team 3-3, Briggs Fall 2023 회원
CSULA-BRIGGS-F23S3G3
3 회원들
안내서 4개를 작성함
3가이드 댓글
I've been doing this regularly, usually it lasts less than a year. Are there any replacement kits that are more durable, or are they all equally flimsy?
Creaky Recoil - 답글 공유
Broken headband? This an obvious design flaw but keeps the company in the green. There is way too much stress from the hinges put upon the little plastic tabs which act as screw posts on each end of the headband. In a perfect world the headband would be made of steel or reinforced with wire all the way into the screw posts. Perhaps oiling the spring hinge lock tabs and seats would help alleviate some stresses from folding/unfolding but there is still a lot of force applied to these two little plastic tabs on each side of the headband.
Junk design but a win-win for Apple. Since replacement headbands are in the $20 range (they do come in matching colors) and typically last about 10-12 months or less as previous poster says, Beats are a money magnet. If Dre really uses these he probably wears them for a day or two then tosses them before they could break anyway.
Paul B - 답글 공유
I pretty much was moments away from ordering a new pair of headphones when I decided to see if there’s any way to resurrect my headphone. Not only was it easy to repair I’ve saved hundreds of dollars by simply following his step by step instructions which was easy to follow. Thanks again 👍🏾
Derrell Dudley - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 6
지난 7일: 50
지난 30일: 308
전체 시간: 10,003
