주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Beats Studio First Generation Batteries Replacement
필요한 것
    1. Beats Studio First Generation Batteries Replacement, Identify the Left Speaker Housing: 1 단계, 이미지 1개 중 1개
      • The left speaker is the speaker that holds the batteries and does not have the power switch.
      댓글 쓰기
    2. Beats Studio First Generation Batteries Replacement, Removing the Battery Cap: 2 단계, 이미지 3개 중 1개 Beats Studio First Generation Batteries Replacement, Removing the Battery Cap: 2 단계, 이미지 3개 중 2개 Beats Studio First Generation Batteries Replacement, Removing the Battery Cap: 2 단계, 이미지 3개 중 3개
      • Place two fingers on each side of the cap. Press and twist counterclockwise to loosen the cap.
      • Once the cap is loose, simply lift the cap out to reveal the batteries.
      댓글 쓰기
    3. Beats Studio First Generation Batteries Replacement, Batteries!: 3 단계, 이미지 1개 중 1개
      • Carefully pull the batteries out of their housings. When putting in new batteries, make sure that you place each battery in the correct orientation.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 24명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Oscar
회원 가입일: 04/15/14
1,216 평판
안내서 2개를 작성함
Cal Poly, Team 9-18, Regan Spring 2014 Cal Poly, Team 9-18, Regan Spring 2014 회원
CPSU-REGAN-S14S9G18
4 회원들
안내서 25개를 작성함
29가이드 댓글
hi man you post is help me a lot thank you..God bless you
EL TIO SAM MARS - 답글 공유
Are u using 4A batteries on this? Please reply ASAP. The 3a batteries won't fit on my beats wireless studio.
Nessa Upzs - 답글 공유
They are 2 x AAA batteries. This is Beats Studio first generation which are WIRED headphones.
John Coops - 답글 공유
Help,I'm trying to twist off battery compartment and it's not budging! Should I try and pry off w/screwdriver! Any ideas?
Kathy - 답글 공유
hello jus curious if u got the cap to come off n how if so? any advice wld b greatly appreciated please n thank u
Randi - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 8
지난 7일: 57
지난 30일: 185
전체 시간: 153,824
