주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Beats Studio First Generation Headband Replacement
필요한 것
    1. Beats Studio First Generation Headband Replacement, Removing the outer headband screws.: 1 단계, 이미지 1개 중 1개
      • Using the T5 Torx screwdriver, remove the black screws on both sides of the outside of the headband.
      • 4 (2 per side) Torx type T5, 3.5mm long screws.
      댓글 쓰기
    2. Beats Studio First Generation Headband Replacement, Removing the plastic hinge guards.: 2 단계, 이미지 2개 중 1개 Beats Studio First Generation Headband Replacement, Removing the plastic hinge guards.: 2 단계, 이미지 2개 중 2개
      • Use the plastic opening tool to gently pry the black plastic hinge piece directly away from the headband as shown.
      댓글 쓰기
    3. Beats Studio First Generation Headband Replacement, Removing the hinge pins.: 3 단계, 이미지 1개 중 1개
      • Remove the small metal hinges from their housings. There are a total of 4 hinges, two per side of the headphones.
      • The hinge pins may slide out upon removal of the black hinge piece from the previous step. Be careful not to lose the hinge pins.
      댓글 쓰기
    4. Beats Studio First Generation Headband Replacement, Removing the metal bands.: 4 단계, 이미지 1개 중 1개
      • Using a T5 Torx screwdriver, remove the silver screws from the silver segment of the headband.
      • 4 (2 per side) Torx type T5, 4.0mm long screws.
      댓글 쓰기
    5. Beats Studio First Generation Headband Replacement, Removing the headband cushion.: 5 단계, 이미지 3개 중 1개 Beats Studio First Generation Headband Replacement, Removing the headband cushion.: 5 단계, 이미지 3개 중 2개 Beats Studio First Generation Headband Replacement, Removing the headband cushion.: 5 단계, 이미지 3개 중 3개
      • Using the plastic opening tool, gently pry the headband cushion directly away from the plastic portion of the headband as shown. Pry the plastic portion a small amount and then move the opening tool sideways along on the headband. Repeat on both sides until the cushion separates from the top plastic part of the headband.
      댓글 쓰기
    6. Beats Studio First Generation Headband Replacement, Removing the metal headband support.: 6 단계, 이미지 2개 중 1개 Beats Studio First Generation Headband Replacement, Removing the metal headband support.: 6 단계, 이미지 2개 중 2개
      • Carefully remove the metal band from each of the hinge housings on each side. These should come off quite easily, provided that you have removed the hinges as instructed in step 3.
      • Congratulations, you have completely removed the headband! This will allow for ease of accessibility to the speakers should you choose to delve further into the depths of your headphones.
      • The black wire connecting the two speakers is somewhat fragile! Check that it isn't frayed. If it is frayed, consider repairing it with some electrical tape, splicing it, or replacing it.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 20명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Anand Mangal
회원 가입일: 04/15/14
1,101 평판
안내서 2개를 작성함
Cal Poly, Team 9-18, Regan Spring 2014 Cal Poly, Team 9-18, Regan Spring 2014 회원
CPSU-REGAN-S14S9G18
4 회원들
안내서 25개를 작성함
2가이드 댓글
where can i buy the pin for the hinge i woud like you know email the link to this email drkimaging@gmail.com
derek - 답글 공유
When replacing the headband there is no need to remove any screws or hinges for the beats studio 1.0 as described here.
Simply carefully remove the headband cushion by snapping it out from the frame as it is merely a push fir and not reattained at the two ends it is just push fit into the top plastic section. Just tease it out gently with small screwdriver and then the the replacement in place and listen to the click as it snaps in. Simple and easy takes less than a minute.
Roger Holland - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 38
지난 30일: 99
전체 시간: 82,822
