주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Bed Head Curlipops Heating Element Replacement
필요한 것
    1. Bed Head Curlipops Heating Element Replacement, Handle Casing: 1 단계, 이미지 1개 중 1개
      • Remove all four of the 4 mm Phillips screws on either side of the casing.
      댓글 쓰기
    2. Bed Head Curlipops Heating Element Replacement: 2 단계, 이미지 1개 중 1개
      • Using an opening tool, insert it along the seam where both halves of the casing meet, and slowly pry the left side of the casing from the right.
      • Gently pull back the right side of the casing from the center molding.
      댓글 쓰기
    1. Bed Head Curlipops Heating Element Replacement, On Switch: 3 단계, 이미지 1개 중 1개
      • Move wiring or other components away from the main soldering field.
      댓글 쓰기
    2. Bed Head Curlipops Heating Element Replacement: 4 단계, 이미지 2개 중 1개 Bed Head Curlipops Heating Element Replacement: 4 단계, 이미지 2개 중 2개
      • Release the securing tabs on the switch to the center molding.
      • Use a 4mm flat head screwdriver to break off the solder where the wires meet the switch.
      댓글 쓰기
    3. Bed Head Curlipops Heating Element Replacement: 5 단계, 이미지 1개 중 1개
      • Press the new switch back into the center molding and use a soldering iron to solder the wires on the new switch.
      댓글 쓰기
    1. Bed Head Curlipops Heating Element Replacement, Heating Element: 6 단계, 이미지 2개 중 1개 Bed Head Curlipops Heating Element Replacement, Heating Element: 6 단계, 이미지 2개 중 2개
      • Remove the four 4 mm Phillips screws shown on the heating element housing.
      • Pull back on the heater housing to release it from the main handle molding.
      댓글 쓰기
    2. Bed Head Curlipops Heating Element Replacement: 7 단계, 이미지 2개 중 1개 Bed Head Curlipops Heating Element Replacement: 7 단계, 이미지 2개 중 2개
      • Locate the wiring of the heating element on the switch.
      • Remove the solder from both wires.
      • Once both wires are released, pull back on the heating element to release it from the assembly.
      댓글 쓰기
    3. Bed Head Curlipops Heating Element Replacement: 8 단계, 이미지 1개 중 1개
      • Use a soldering iron to reconnect the heating element wires to the metal tabs on the switch.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
4다른 기여자 명과 함께
Landon Pinto
회원 가입일: 03/21/25
649 평판
안내서 4개를 작성함
UMass Dartmouth, Team 3-6, Botvin Spring 2025 UMass Dartmouth, Team 3-6, Botvin Spring 2025 회원
UMASSD-BOTVIN-S25S3G6
3 회원들
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 22
전체 시간: 188
