주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Belkin NetCam HD Lens Piece Replacement
필요한 것
    1. Belkin NetCam HD Lens Piece  Replacement, Case: 1 단계, 이미지 1개 중 1개
      • Use a wrench to loosen up the stand from the back in order to hold the NetCam more comfortably.
      댓글 쓰기
    2. Belkin NetCam HD Lens Piece  Replacement: 2 단계, 이미지 1개 중 1개
      • Work a plastic opening tool into the seam and pry the face plate away from the back panel.
      댓글 쓰기
    3. Belkin NetCam HD Lens Piece  Replacement: 3 단계, 이미지 2개 중 1개 Belkin NetCam HD Lens Piece  Replacement: 3 단계, 이미지 2개 중 2개
      • Use pressure to separate the covers.
      • When pulling the device apart, separate from the bottom up in order to avoid pulling the wiring at the top apart.
      댓글 쓰기
    1. Belkin NetCam HD Lens Piece  Replacement, Front Casing: 4 단계, 이미지 1개 중 1개
      • Carefully use your fingers to gently pull out the white attachment from the tan colored part.
      댓글 쓰기
    1. Belkin NetCam HD Lens Piece  Replacement, Speaker: 5 단계, 이미지 2개 중 1개 Belkin NetCam HD Lens Piece  Replacement, Speaker: 5 단계, 이미지 2개 중 2개
      • Use a Phillips #0 screwdriver to take out the two 1.2 mm screws on the board.
      댓글 쓰기
    2. Belkin NetCam HD Lens Piece  Replacement: 6 단계, 이미지 3개 중 1개 Belkin NetCam HD Lens Piece  Replacement: 6 단계, 이미지 3개 중 2개 Belkin NetCam HD Lens Piece  Replacement: 6 단계, 이미지 3개 중 3개
      • With your fingers, pull the circuit board out of the back casing.
      • When pulling the board up be sure to do so carefully so you do not break the cord which is attached on the back side.
      댓글 쓰기
    3. Belkin NetCam HD Lens Piece  Replacement: 7 단계, 이미지 2개 중 1개 Belkin NetCam HD Lens Piece  Replacement: 7 단계, 이미지 2개 중 2개
      • Gently pull the speaker out of the holder from the back of the cover.
      댓글 쓰기
    4. Belkin NetCam HD Lens Piece  Replacement: 8 단계, 이미지 1개 중 1개
      • The speaker wires are attached with the board. It can be unattached gently by pulling out the white attachment from the port.
      댓글 쓰기
    1. Belkin NetCam HD Lens Piece  Replacement, Lens Piece: 9 단계, 이미지 2개 중 1개 Belkin NetCam HD Lens Piece  Replacement, Lens Piece: 9 단계, 이미지 2개 중 2개
      • Flip the circuit board to the back side.
      • Fold down the tape with your finger.
      • With the Phillips #0 screwdriver, unscrew the two 1.2 mm screws.
      댓글 쓰기
    2. Belkin NetCam HD Lens Piece  Replacement: 10 단계, 이미지 2개 중 1개 Belkin NetCam HD Lens Piece  Replacement: 10 단계, 이미지 2개 중 2개
      • Flip the circuit board back to the other side.
      • Unscrew the screw with a Phillips #0 screw driver.
      댓글 쓰기
    3. Belkin NetCam HD Lens Piece  Replacement: 11 단계, 이미지 1개 중 1개
      • Slide the attached piece from the lens holder device.
      댓글 쓰기
    4. Belkin NetCam HD Lens Piece  Replacement: 12 단계, 이미지 2개 중 1개 Belkin NetCam HD Lens Piece  Replacement: 12 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      • Use the tweezers to pull the white attachment out from the port a little.
      • Then, take your fingers and gently pull the white attachment out from the tan port.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
6다른 기여자 명과 함께
Destinie DiazVerdejo
회원 가입일: 10/04/16
805 평판
안내서 7개를 작성함
USF Tampa, Team 3-5, Sullivan Fall 2016 USF Tampa, Team 3-5, Sullivan Fall 2016 회원
USFT-SULLIVAN-F16S3G5
4 회원들
안내서 21개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 26
전체 시간: 1,406
