주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Belt Loop Keeper Replacement
필요한 것
    1. Belt Loop Keeper Replacement, Belt Loop Keeper: 1 단계, 이미지 2개 중 1개 Belt Loop Keeper Replacement, Belt Loop Keeper: 1 단계, 이미지 2개 중 2개
      • Measure the pieces of leather so the resulting strap will wrap around with a width of 0.5 in and a 1 cm overlap.
      댓글 쓰기
    2. Belt Loop Keeper Replacement: 2 단계, 이미지 2개 중 1개 Belt Loop Keeper Replacement: 2 단계, 이미지 2개 중 2개
      • Mark the measurements with an indent.
      • Our belt was 1.5 in wide; the leather strap we measured was 4 x 0.5 in.
      • Cut the leather strap using scissors or a pocket knife.
      • Caution: Hazardous situation which, if not avoided, could result in minor or moderate injury.
      댓글 쓰기
    3. Belt Loop Keeper Replacement: 3 단계, 이미지 2개 중 1개 Belt Loop Keeper Replacement: 3 단계, 이미지 2개 중 2개
      • Wrap the leather strap around the belt with 1 cm of overlap.
      • Mark the area underneath where the leather piece will overlap to center the eyelet.
      댓글 쓰기
    4. Belt Loop Keeper Replacement: 4 단계, 이미지 1개 중 1개
      • Place an eyelet on the inner flat side of the eyelet pliers.
      댓글 쓰기
    5. Belt Loop Keeper Replacement: 5 단계, 이미지 2개 중 1개 Belt Loop Keeper Replacement: 5 단계, 이미지 2개 중 2개
      • Placing the loop of leather in between the pliers, center the eyelet on the indent previously made and press down firmly.
      • Use a hammer to strike the outside of the pliers for additional force.
      댓글 쓰기
    6. Belt Loop Keeper Replacement: 6 단계, 이미지 3개 중 1개 Belt Loop Keeper Replacement: 6 단계, 이미지 3개 중 2개 Belt Loop Keeper Replacement: 6 단계, 이미지 3개 중 3개
      • Make sure both sides of the leather loop are secured.
      • Insert the belt tail into the leather loop.
      • Slide down the desired belt.
      댓글 쓰기
    7. Belt Loop Keeper Replacement: 7 단계, 이미지 2개 중 1개 Belt Loop Keeper Replacement: 7 단계, 이미지 2개 중 2개
      • Buckle the belt and insert the excess belt material into the belt loop keeper.
      • Adjust until satisfied.
      댓글 쓰기
결승점
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Shel Rivas
회원 가입일: 11/05/24
193 평판
안내서 1개를 작성함
UC Davis, Team 3-1, Vidal-Chiesa Fall 2024 UC Davis, Team 3-1, Vidal-Chiesa Fall 2024 회원
UCD-VIDAL-CHIESA-F24S3G1
3 회원들
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 19
지난 30일: 150
전체 시간: 2,583
