주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
BenQ HT1075 Projector Blower Fan Replacement
필요한 것
    1. BenQ HT1075 Projector Blower Fan Replacement, Lamp: 1 단계, 이미지 1개 중 1개
      • Loosen the 2.5 mm Phillips #1 screw that holds the top assembly in place using a Philips #1 (PH1) screwdriver. This will enable you to lift and slide off the top cover.
      • Fully remove the top cover in order to get to the lamp housing.
      댓글 쓰기
    2. BenQ HT1075 Projector Blower Fan Replacement: 2 단계, 이미지 1개 중 1개
      • Carefully peel off the adhesive film covering the lamp housing.
      댓글 쓰기
    3. BenQ HT1075 Projector Blower Fan Replacement: 3 단계, 이미지 1개 중 1개
      • Using a Phillips #1 (PH1) screwdriver, loosen and remove the single 2.5 mm Phillips #1 screw that secures the lamp housing to the projector.
      댓글 쓰기
    4. BenQ HT1075 Projector Blower Fan Replacement: 4 단계, 이미지 1개 중 1개
      • Remove the lamp from the projector by pulling on the lamp handle.
      • Apply more force on the side opposite of the newly removed screw as you pull the lamp out.
      댓글 쓰기
    1. BenQ HT1075 Projector Blower Fan Replacement, Circuit Board: 5 단계, 이미지 1개 중 1개
      • Turn the projector over and remove the five 9.5 mm Phillips #1 screws that hold the back cover with a Phillips #1 (PH1) screwdriver.
      댓글 쓰기
    2. BenQ HT1075 Projector Blower Fan Replacement, Remove the 6th screw holding the top cover: 6 단계, 이미지 1개 중 1개
      • Flip the projector and remove the 6th and last crew.
      댓글 쓰기
    3. BenQ HT1075 Projector Blower Fan Replacement: 7 단계, 이미지 1개 중 1개
      • Using an opening tool, remove the top cover by first loosening its top cover.
      댓글 쓰기
    4. BenQ HT1075 Projector Blower Fan Replacement: 8 단계, 이미지 2개 중 1개 BenQ HT1075 Projector Blower Fan Replacement: 8 단계, 이미지 2개 중 2개
      • Unplug the wire that connects the front cover to the circuit board.
      • Now use the opening tool to pry the front cover from the platform.
      • Gently pull the top cover from the rest of the frame.
      댓글 쓰기
    5. BenQ HT1075 Projector Blower Fan Replacement: 9 단계, 이미지 2개 중 1개 BenQ HT1075 Projector Blower Fan Replacement: 9 단계, 이미지 2개 중 2개
      • To prevent potential for electrical damage, disconnect any wires connected to the circuit board.
      • Using the opening tool, loosen the sides of the platform. Then gently pull them off from the projector components.
      댓글 쓰기
    6. BenQ HT1075 Projector Blower Fan Replacement: 10 단계, 이미지 3개 중 1개 BenQ HT1075 Projector Blower Fan Replacement: 10 단계, 이미지 3개 중 2개 BenQ HT1075 Projector Blower Fan Replacement: 10 단계, 이미지 3개 중 3개
      • Remove these four 8.5 mm Phillips #1 screws using a Phillips #1 (PH1) screwdriver.
      • Afterwards, use a 5mm nut driver to remove the four remaining screws.
      • Use the opening tool to loosen the back cover then pull it off.
      댓글 쓰기
    7. BenQ HT1075 Projector Blower Fan Replacement: 11 단계, 이미지 1개 중 1개
      • With a Phillips #1 (PH1) screwdriver, remove the four 6.3 mm Phillips screws that hold the metal casing on top of the circuit board.
      • Remove the metal casing.
      댓글 쓰기
    8. BenQ HT1075 Projector Blower Fan Replacement: 12 단계, 이미지 2개 중 1개 BenQ HT1075 Projector Blower Fan Replacement: 12 단계, 이미지 2개 중 2개
      • Using the Phillips #1 (PH1) screwdriver, remove the three 6.3 mm Phillips #1 screws holding down the circuit board.
      • Carefully pull the circuit board from the frame, adding force to the area where the pushbuttons are located.
      댓글 쓰기
    1. BenQ HT1075 Projector Blower Fan Replacement, Blower Fan: 13 단계, 이미지 2개 중 1개 BenQ HT1075 Projector Blower Fan Replacement, Blower Fan: 13 단계, 이미지 2개 중 2개
      • Unscrew the Philips #1 (PH1) screw securing the green wire located at the bottom left of the metal casing.
      • Remove a second Philips #1 (PH1) screw that holds down the top of the metal casing located near the back of the projector’s lens.
      댓글 쓰기
    2. BenQ HT1075 Projector Blower Fan Replacement: 14 단계, 이미지 1개 중 1개
      • Remove three Philips #2 (PH2) screws that attach the metal casing to the platform.
      • Remove the metal casing by pulling it straight up.
      댓글 쓰기
    3. BenQ HT1075 Projector Blower Fan Replacement: 15 단계, 이미지 1개 중 1개
      • Remove the two Philips #2 (PH2) screws that hold down the black blower fan, located at top center of the circuit board.
      댓글 쓰기
    4. BenQ HT1075 Projector Blower Fan Replacement: 16 단계, 이미지 1개 중 1개
      • Remove the three Philips #1 (PH1) screws that attach the blower fan to the metal cover.
      • Gently remove the blower fan by pulling it directly upwards from the base.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 7명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Gabriela Remulla
회원 가입일: 09/26/17
1,026 평판
안내서 5개를 작성함
Cal Poly, Team S6-G1, Banghart Fall 2017 Cal Poly, Team S6-G1, Banghart Fall 2017 회원
CPSU-BANGHART-F17S6G1
5 회원들
안내서 19개를 작성함
3가이드 댓글
I did the repair to clear out some dust and glass from a blown lamp. After putting it back together, I get lights most likely from no power at all. Do you think the next step would to be take back apart and make sure everything is connected correctly? I can be reached at jaspercloren@gmail.com or I will check back on here.
Thank you for all your write ups, they are very nice. I may suggest to get a closer view of the screws/bolts in case someone misplaces one.
Jasper Loren - 답글 공유
where can we buy the replacement fan? Is there a part number for finding this part?
Rekhender Dhawan - 답글 공유
Le Bon F - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 14
지난 30일: 62
전체 시간: 10,549
