주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
BlackBerry 7100g Battery Terminal Replacement
필요한 것
  1. BlackBerry 7100g Battery Terminal Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Turn over your BalckBerry 7100g so that the back cover is facing up.
    • Locate the battery cover release button near the bottom of the back panel.
    댓글 쓰기
  2. BlackBerry 7100g Battery Terminal Replacement: 2 단계, 이미지 3개 중 1개 BlackBerry 7100g Battery Terminal Replacement: 2 단계, 이미지 3개 중 2개 BlackBerry 7100g Battery Terminal Replacement: 2 단계, 이미지 3개 중 3개
    • Push down on the release button with one thumb.
    • Slide the battery cover off with the other thumb.
    댓글 쓰기
  3. BlackBerry 7100g Battery Terminal Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the battery from the battery housing by flipping up the top of the battery.
    댓글 쓰기
  4. BlackBerry 7100g Battery Terminal Replacement, Housing: 4 단계, 이미지 3개 중 1개 BlackBerry 7100g Battery Terminal Replacement, Housing: 4 단계, 이미지 3개 중 2개 BlackBerry 7100g Battery Terminal Replacement, Housing: 4 단계, 이미지 3개 중 3개
    • Locate the silver strip near the top of your BlackBerry.
    • Use a plastic opening tool to pry off the edge of the silver lining.
    • Slide the tool along the length of the silver strip to completely remove it.
    댓글 쓰기
  5. BlackBerry 7100g Battery Terminal Replacement: 5 단계, 이미지 2개 중 1개 BlackBerry 7100g Battery Terminal Replacement: 5 단계, 이미지 2개 중 2개
    • Do not lose the screws. They are quite small and can easily be misplaced.
    • Locate and unscrew the four (4) screws using a T6 screwdriver.
    댓글 쓰기
  6. BlackBerry 7100g Battery Terminal Replacement: 6 단계, 이미지 3개 중 1개 BlackBerry 7100g Battery Terminal Replacement: 6 단계, 이미지 3개 중 2개 BlackBerry 7100g Battery Terminal Replacement: 6 단계, 이미지 3개 중 3개
    • The keypad cover may fall out of the housing when prying the housing apart.
    • Tightly pinch the top of the front and back halves of the housing.
    • Carefully pry the two halves of the housing apart.
    댓글 쓰기
  7. BlackBerry 7100g Battery Terminal Replacement: 7 단계, 이미지 1개 중 1개
    • You can now easily remove the "guts" of the phone from the housing.
    댓글 쓰기
  8. BlackBerry 7100g Battery Terminal Replacement, Battery Terminal: 8 단계, 이미지 2개 중 1개 BlackBerry 7100g Battery Terminal Replacement, Battery Terminal: 8 단계, 이미지 2개 중 2개
    • Remove the four screws holding the battery and speaker housing to the motherboard.
    댓글 쓰기
  9. BlackBerry 7100g Battery Terminal Replacement: 9 단계, 이미지 3개 중 1개 BlackBerry 7100g Battery Terminal Replacement: 9 단계, 이미지 3개 중 2개 BlackBerry 7100g Battery Terminal Replacement: 9 단계, 이미지 3개 중 3개
    • Once the battery housing is seperated from the motherboard, the battery terminal will slide off the battery housing.
    • The small plastic piece with four metal pins is the battery terminal shown in the third picture.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
4다른 기여자 명과 함께
Kellan
회원 가입일: 03/30/10
277 평판
안내서 3개를 작성함
Cal Poly, Team 25-87, Amido Spring 2010 Cal Poly, Team 25-87, Amido Spring 2010 회원
CPSU-AMIDO-S10S25G87
4 회원들
안내서 17개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 10
지난 30일: 42
전체 시간: 3,525
