주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
BlackBerry 7100g Screen Replacement
필요한 것
  1. BlackBerry 7100g Screen Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Turn over your BalckBerry 7100g so that the back cover is facing up.
    • Locate the battery cover release button near the bottom of the back panel.
    댓글 쓰기
  2. BlackBerry 7100g Screen Replacement: 2 단계, 이미지 3개 중 1개 BlackBerry 7100g Screen Replacement: 2 단계, 이미지 3개 중 2개 BlackBerry 7100g Screen Replacement: 2 단계, 이미지 3개 중 3개
    • Push down on the release button with one thumb.
    • Slide the battery cover off with the other thumb.
    댓글 쓰기
  3. BlackBerry 7100g Screen Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the battery from the battery housing by flipping up the top of the battery.
    댓글 쓰기
  4. BlackBerry 7100g Screen Replacement, Housing: 4 단계, 이미지 3개 중 1개 BlackBerry 7100g Screen Replacement, Housing: 4 단계, 이미지 3개 중 2개 BlackBerry 7100g Screen Replacement, Housing: 4 단계, 이미지 3개 중 3개
    • Locate the silver strip near the top of your BlackBerry.
    • Use a plastic opening tool to pry off the edge of the silver lining.
    • Slide the tool along the length of the silver strip to completely remove it.
    댓글 쓰기
  5. BlackBerry 7100g Screen Replacement: 5 단계, 이미지 2개 중 1개 BlackBerry 7100g Screen Replacement: 5 단계, 이미지 2개 중 2개
    • Do not lose the screws. They are quite small and can easily be misplaced.
    • Locate and unscrew the four (4) screws using a T6 screwdriver.
    댓글 쓰기
  6. BlackBerry 7100g Screen Replacement: 6 단계, 이미지 3개 중 1개 BlackBerry 7100g Screen Replacement: 6 단계, 이미지 3개 중 2개 BlackBerry 7100g Screen Replacement: 6 단계, 이미지 3개 중 3개
    • The keypad cover may fall out of the housing when prying the housing apart.
    • Tightly pinch the top of the front and back halves of the housing.
    • Carefully pry the two halves of the housing apart.
    댓글 쓰기
  7. BlackBerry 7100g Screen Replacement: 7 단계, 이미지 1개 중 1개
    • You can now easily remove the "guts" of the phone from the housing.
    댓글 쓰기
  8. BlackBerry 7100g Screen Replacement, Keypad: 8 단계, 이미지 3개 중 1개 BlackBerry 7100g Screen Replacement, Keypad: 8 단계, 이미지 3개 중 2개 BlackBerry 7100g Screen Replacement, Keypad: 8 단계, 이미지 3개 중 3개
    • Turn the "guts" over so the speaker is facing up.
    • Locate and unscrew the four (4) screws near the bottom of the motherboard, using a T6 screwdriver.
    • Separate the battery housing from the motherboard.
    댓글 쓰기
  9. BlackBerry 7100g Screen Replacement: 9 단계, 이미지 1개 중 1개
    • Pull the keypad off of the motherboard.
    • It should come off with little effort. If not, there are several tabs that can be released on either side of the keypad.
    댓글 쓰기
  10. BlackBerry 7100g Screen Replacement, Screen: 10 단계, 이미지 2개 중 1개 BlackBerry 7100g Screen Replacement, Screen: 10 단계, 이미지 2개 중 2개
    • Locate the ribbon connector below the bottom of the screen.
    • Use a spudger to flip up the connector.
    댓글 쓰기
  11. BlackBerry 7100g Screen Replacement: 11 단계, 이미지 3개 중 1개 BlackBerry 7100g Screen Replacement: 11 단계, 이미지 3개 중 2개 BlackBerry 7100g Screen Replacement: 11 단계, 이미지 3개 중 3개
    • Locate the four (4) white tabs that attach the screen to the motherboard.
    • Carefully detach the tabs from the motherboard.
    • The screen can now be removed from the motherboard.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Adriel Salinas
회원 가입일: 04/11/10
42 평판
안내서 2개를 작성함
Cal Poly, Team 25-87, Amido Spring 2010 Cal Poly, Team 25-87, Amido Spring 2010 회원
CPSU-AMIDO-S10S25G87
4 회원들
안내서 17개를 작성함
1가이드 댓글
just a heads up don't do this with a iPhone it does not work at All!
Jaxson HUTCHINSON - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 34
전체 시간: 2,298
