주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
BlackBerry 7280 Inner Keyboard Replacement
필요한 것
  1. BlackBerry 7280 Inner Keyboard Replacement, Battery: 1 단계, 이미지 3개 중 1개 BlackBerry 7280 Inner Keyboard Replacement, Battery: 1 단계, 이미지 3개 중 2개 BlackBerry 7280 Inner Keyboard Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • With your thumb press down on the locking- button on the back of the BlackBerry 7280.
    • Slide the battery cover off the device.
    댓글 쓰기
  2. BlackBerry 7280 Inner Keyboard Replacement: 2 단계, 이미지 2개 중 1개 BlackBerry 7280 Inner Keyboard Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the lithium-ion battery from the back of the device using your index finger.
    댓글 쓰기
  3. BlackBerry 7280 Inner Keyboard Replacement, SIM Card: 3 단계, 이미지 3개 중 1개 BlackBerry 7280 Inner Keyboard Replacement, SIM Card: 3 단계, 이미지 3개 중 2개 BlackBerry 7280 Inner Keyboard Replacement, SIM Card: 3 단계, 이미지 3개 중 3개
    • Hold the device with both hands.
    • Lift the SIM card holder using your thumb and index finger.
    • Remove the SIM card from the device.
    댓글 쓰기
  4. BlackBerry 7280 Inner Keyboard Replacement, Back Case: 4 단계, 이미지 2개 중 1개 BlackBerry 7280 Inner Keyboard Replacement, Back Case: 4 단계, 이미지 2개 중 2개
    • Using a Torx T6 screwdriver, remove all six 1/8 inch screws (marked in red) from the back case. Set screws aside.
    • The SIM card has been removed here to prevent damage to the card. This is recommended, but not not required.
    댓글 쓰기
  5. BlackBerry 7280 Inner Keyboard Replacement: 5 단계, 이미지 2개 중 1개 BlackBerry 7280 Inner Keyboard Replacement: 5 단계, 이미지 2개 중 2개
    • Use the plastic opening tool to pry the back case away from the front case.
    댓글 쓰기
  6. BlackBerry 7280 Inner Keyboard Replacement, Front Case: 6 단계, 이미지 2개 중 1개 BlackBerry 7280 Inner Keyboard Replacement, Front Case: 6 단계, 이미지 2개 중 2개
    • Using a Torx T6 screwdriver, remove the lone 1/8 inch screw that holds the upper metal bracket onto the larger metal bracket. Set aside the screw and the bracket.
    댓글 쓰기
  7. BlackBerry 7280 Inner Keyboard Replacement: 7 단계, 이미지 2개 중 1개 BlackBerry 7280 Inner Keyboard Replacement: 7 단계, 이미지 2개 중 2개
    • Remove the front plastic case from the metal bracket.
    댓글 쓰기
  8. BlackBerry 7280 Inner Keyboard Replacement, Inner Keyboard: 8 단계, 이미지 1개 중 1개
    • To remove the inner keyboard, simply peel it off of the logic board as shown.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
4다른 기여자 명과 함께
Andrew Johnston
회원 가입일: 03/11/13
4 평판
안내서 2개를 작성함
Clemson, Team 12-2, Benson Spring 2013 Clemson, Team 12-2, Benson Spring 2013 회원
CLEM-BENSON-S13S12G2
4 회원들
안내서 21개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 18
전체 시간: 540
