주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
BlackBerry Curve 8530 Keypad Replacement
필요한 것
  1. BlackBerry Curve 8530 Keypad Replacement, Battery: 1 단계, 이미지 2개 중 1개 BlackBerry Curve 8530 Keypad Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Place the phone on a flat surface with the screen facing down.
    • Remove the plastic backplate by pulling up on the bottom of the cover.
    댓글 쓰기
  2. BlackBerry Curve 8530 Keypad Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the battery by pulling up from the top of the battery.
    댓글 쓰기
  3. BlackBerry Curve 8530 Keypad Replacement, Keypad: 3 단계, 이미지 2개 중 1개 BlackBerry Curve 8530 Keypad Replacement, Keypad: 3 단계, 이미지 2개 중 2개
    • Remove the two screws midway up the phone on the left and right sides using a T6 Torx Screwdriver.
    • Warning: One screw will have warranty tape covering the screw. Removing this screw will likely void the phones warranty.
    댓글 쓰기
  4. BlackBerry Curve 8530 Keypad Replacement: 4 단계, 이미지 2개 중 1개 BlackBerry Curve 8530 Keypad Replacement: 4 단계, 이미지 2개 중 2개
    • Flip the phone over so the keyboard faces up.
    • Insert a plastic spudger into the screen where speaker resides.
    • I recommend going from the side. There are two layers to the cover. You need to make sure you get underneath the bottom layer if you plan on reusing this cover.
    • Gently lift up plastic screen cover until screen cover separates from screen.
    • Continue until screen cover is completely removed.
    댓글 쓰기
  5. BlackBerry Curve 8530 Keypad Replacement: 5 단계, 이미지 3개 중 1개 BlackBerry Curve 8530 Keypad Replacement: 5 단계, 이미지 3개 중 2개 BlackBerry Curve 8530 Keypad Replacement: 5 단계, 이미지 3개 중 3개
    • Insert the spudger into the top of the plastic siding on the front of the phone and lift up until the siding lifts up.
    • Slide the tool around the entire perimeter of the phone until the plastic siding is completely removed.
    댓글 쓰기
  6. BlackBerry Curve 8530 Keypad Replacement: 6 단계, 이미지 2개 중 1개 BlackBerry Curve 8530 Keypad Replacement: 6 단계, 이미지 2개 중 2개
    • The keyboard should slide off of the phone now that the plastic siding has been removed.
    댓글 쓰기
결론
To reassemble the device, follow the instructions in reverse order.
취소: 해당 안내서를 완성하지 않았습니다.
다른 4명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Cory Davis
회원 가입일: 04/19/11
503 평판
안내서 3개를 작성함
Cal Poly, Team 15-13, Regan Spring 2011 Cal Poly, Team 15-13, Regan Spring 2011 회원
CPSU-REGAN-S11S15G13
3 회원들
안내서 6개를 작성함
1가이드 댓글
This is a handy technique I will use it when next time I fix my phone and if you get time do visit us we fix these type of problems in India, Kolkata here is our site link https://techyuga.com/kolkata/
Ankita - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 34
전체 시간: 6,801
