주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
BlackBerry PlayBook Camera Replacement
필요한 것
    1. BlackBerry PlayBook Camera Replacement, Remove Back Panel: 1 단계, 이미지 2개 중 1개 BlackBerry PlayBook Camera Replacement, Remove Back Panel: 1 단계, 이미지 2개 중 2개
      • Use a plastic opening tool to pry the back panel off by inserting it in between the front and back panel.
      • There are clips that need to be released on all four sides of the device.
      • When replacing the back cover insert the bottom side first ( usb and hdmi ports stick out about 2mm ) inserting them into the covers openings will allow for easier reassembly
      댓글 쓰기
    1. BlackBerry PlayBook Camera Replacement, Motherboard: 2 단계, 이미지 2개 중 1개 BlackBerry PlayBook Camera Replacement, Motherboard: 2 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      • Remove the battery connector using either your fingers or a pair of tweezers.
      댓글 쓰기
    2. BlackBerry PlayBook Camera Replacement: 3 단계, 이미지 2개 중 1개 BlackBerry PlayBook Camera Replacement: 3 단계, 이미지 2개 중 2개
      • Unscrew two 1.17x2.9mm Phillips screws from the white connector port.
      • Lift the battery connector away from the motherboard using a spudger.
      댓글 쓰기
    3. BlackBerry PlayBook Camera Replacement: 4 단계, 이미지 2개 중 1개 BlackBerry PlayBook Camera Replacement: 4 단계, 이미지 2개 중 2개
      댓글 쓰기
    4. BlackBerry PlayBook Camera Replacement: 5 단계, 이미지 2개 중 1개 BlackBerry PlayBook Camera Replacement: 5 단계, 이미지 2개 중 2개
      댓글 쓰기
    5. BlackBerry PlayBook Camera Replacement: 6 단계, 이미지 3개 중 1개 BlackBerry PlayBook Camera Replacement: 6 단계, 이미지 3개 중 2개 BlackBerry PlayBook Camera Replacement: 6 단계, 이미지 3개 중 3개
      • Remove the clipped ZIF data connector coming from underneath the motherboard.
      • Lift up the black plastic clip with a spudger.
      • Pull the connector out gently using tweezers.
      • Be careful to ensure that the black plastic clip has been lifted away from the connector ribbon before pulling on the connector. The clip should be loose and easy to wiggle. Removing the connector before it is unclipped can cause damage.
      댓글 쓰기
    6. BlackBerry PlayBook Camera Replacement, Unscrew Motherboard: 7 단계, 이미지 1개 중 1개
      • Remove the following five screws from the motherboard.
      • Three 1.5x2.5mm Phillips screws
      • Two 1.55x2.38mm Phillips screws
      댓글 쓰기
    7. BlackBerry PlayBook Camera Replacement, Remove Wire Leads: 8 단계, 이미지 1개 중 1개
      댓글 쓰기
    8. BlackBerry PlayBook Camera Replacement, Remove Motherboard: 9 단계, 이미지 2개 중 1개 BlackBerry PlayBook Camera Replacement, Remove Motherboard: 9 단계, 이미지 2개 중 2개
      • Gently lift the motherboard away from the device. If there is any resistance, check the previous steps to ensure that all connections have been removed.
      댓글 쓰기
    1. BlackBerry PlayBook Camera Replacement, Camera: 10 단계, 이미지 1개 중 1개
      댓글 쓰기
    2. BlackBerry PlayBook Camera Replacement, Remove Camera Assembly: 11 단계, 이미지 2개 중 1개 BlackBerry PlayBook Camera Replacement, Remove Camera Assembly: 11 단계, 이미지 2개 중 2개
      • Pry the camera assembly away from the device, lifting the left side with a spudger.
      • There is a small hook on the right side of the assembly holding it in place. When removing the assembly, be sure to lift it from the left side in order to slide it out from under this hook.
      댓글 쓰기
    3. BlackBerry PlayBook Camera Replacement, Detach Plastic Frame from Cameras: 12 단계, 이미지 2개 중 1개 BlackBerry PlayBook Camera Replacement, Detach Plastic Frame from Cameras: 12 단계, 이미지 2개 중 2개
      • Insert spudger between the plastic frame and circuit board.
      • Gently pry the plastic frame away from the rest of the camera assembly.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Nathan
회원 가입일: 10/12/14
682 평판
안내서 4개를 작성함
Cal Poly, Team 14-27, Maness Fall 2014 Cal Poly, Team 14-27, Maness Fall 2014 회원
CPSU-MANESS-F14S14G27
4 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 31
전체 시간: 3,965
