주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
BlackBerry PlayBook Front Panel Replacement
필요한 것
    1. BlackBerry PlayBook Front Panel Replacement, Remove Back Panel: 1 단계, 이미지 2개 중 1개 BlackBerry PlayBook Front Panel Replacement, Remove Back Panel: 1 단계, 이미지 2개 중 2개
      • Use a plastic opening tool to pry the back panel off by inserting it in between the front and back panel.
      • There are clips that need to be released on all four sides of the device.
      • When replacing the back cover insert the bottom side first ( usb and hdmi ports stick out about 2mm ) inserting them into the covers openings will allow for easier reassembly
      댓글 쓰기
    1. BlackBerry PlayBook Front Panel Replacement, Unscrew Left Speaker: 2 단계, 이미지 1개 중 1개
      • Remove 1.55x.33mm Phillips screw from the metal frame.
      • Remove 1.5x4.25mm Phillips screw from speaker bar.
      댓글 쓰기
    2. BlackBerry PlayBook Front Panel Replacement, Remove the Left Speaker Stickers: 3 단계, 이미지 2개 중 1개 BlackBerry PlayBook Front Panel Replacement, Remove the Left Speaker Stickers: 3 단계, 이미지 2개 중 2개
      • Peel off the stickers holding the left speaker in place with a tweezer or by using your fingers
      댓글 쓰기
    3. BlackBerry PlayBook Front Panel Replacement, Remove Left Speaker: 4 단계, 이미지 2개 중 1개 BlackBerry PlayBook Front Panel Replacement, Remove Left Speaker: 4 단계, 이미지 2개 중 2개
      • Slide the left speaker bar out from its metal bracket.
      댓글 쓰기
    4. BlackBerry PlayBook Front Panel Replacement, Unscrew Right Speaker: 5 단계, 이미지 1개 중 1개
      • Remove both 1.5x4.25mm Phillips screws from the right speaker bar by using the Phillips Screwdriver.
      댓글 쓰기
    5. BlackBerry PlayBook Front Panel Replacement, Remove Right Speaker: 6 단계, 이미지 2개 중 1개 BlackBerry PlayBook Front Panel Replacement, Remove Right Speaker: 6 단계, 이미지 2개 중 2개
      • Lift the right speaker bar to remove it.
      댓글 쓰기
    1. BlackBerry PlayBook Front Panel Replacement, Motherboard: 7 단계, 이미지 2개 중 1개 BlackBerry PlayBook Front Panel Replacement, Motherboard: 7 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      • Remove the battery connector using either your fingers or a pair of tweezers.
      댓글 쓰기
    2. BlackBerry PlayBook Front Panel Replacement: 8 단계, 이미지 2개 중 1개 BlackBerry PlayBook Front Panel Replacement: 8 단계, 이미지 2개 중 2개
      • Unscrew two 1.17x2.9mm Phillips screws from the white connector port.
      • Lift the battery connector away from the motherboard using a spudger.
      댓글 쓰기
    3. BlackBerry PlayBook Front Panel Replacement: 9 단계, 이미지 2개 중 1개 BlackBerry PlayBook Front Panel Replacement: 9 단계, 이미지 2개 중 2개
      댓글 쓰기
    4. BlackBerry PlayBook Front Panel Replacement: 10 단계, 이미지 2개 중 1개 BlackBerry PlayBook Front Panel Replacement: 10 단계, 이미지 2개 중 2개
      댓글 쓰기
    5. BlackBerry PlayBook Front Panel Replacement: 11 단계, 이미지 3개 중 1개 BlackBerry PlayBook Front Panel Replacement: 11 단계, 이미지 3개 중 2개 BlackBerry PlayBook Front Panel Replacement: 11 단계, 이미지 3개 중 3개
      • Remove the clipped ZIF data connector coming from underneath the motherboard.
      • Lift up the black plastic clip with a spudger.
      • Pull the connector out gently using tweezers.
      • Be careful to ensure that the black plastic clip has been lifted away from the connector ribbon before pulling on the connector. The clip should be loose and easy to wiggle. Removing the connector before it is unclipped can cause damage.
      댓글 쓰기
    6. BlackBerry PlayBook Front Panel Replacement, Unscrew Motherboard: 12 단계, 이미지 1개 중 1개
      • Remove the following five screws from the motherboard.
      • Three 1.5x2.5mm Phillips screws
      • Two 1.55x2.38mm Phillips screws
      댓글 쓰기
    7. BlackBerry PlayBook Front Panel Replacement, Remove Wire Leads: 13 단계, 이미지 1개 중 1개
      댓글 쓰기
    8. BlackBerry PlayBook Front Panel Replacement, Remove Motherboard: 14 단계, 이미지 2개 중 1개 BlackBerry PlayBook Front Panel Replacement, Remove Motherboard: 14 단계, 이미지 2개 중 2개
      • Gently lift the motherboard away from the device. If there is any resistance, check the previous steps to ensure that all connections have been removed.
      댓글 쓰기
    1. BlackBerry PlayBook Front Panel Replacement, Unscrew Mid-Frame: 15 단계, 이미지 3개 중 1개 BlackBerry PlayBook Front Panel Replacement, Unscrew Mid-Frame: 15 단계, 이미지 3개 중 2개 BlackBerry PlayBook Front Panel Replacement, Unscrew Mid-Frame: 15 단계, 이미지 3개 중 3개
      • Remove both screws attaching the metal mid-frame to the front panel.
      • Two Phillips screws
      댓글 쓰기
    2. BlackBerry PlayBook Front Panel Replacement, Unscrew Boards from Mid-Frame: 16 단계, 이미지 2개 중 1개 BlackBerry PlayBook Front Panel Replacement, Unscrew Boards from Mid-Frame: 16 단계, 이미지 2개 중 2개
      • Unscrew the small blue boards in each corner with the same Phillips screwdriver.
      댓글 쓰기
    3. BlackBerry PlayBook Front Panel Replacement, Peel Off Sticker: 17 단계, 이미지 2개 중 1개 BlackBerry PlayBook Front Panel Replacement, Peel Off Sticker: 17 단계, 이미지 2개 중 2개
      • Remove the sticker holding the touchscreen controller in place to free it from the mid-frame.
      댓글 쓰기
    4. BlackBerry PlayBook Front Panel Replacement, Unclip Mid-Frame: 18 단계, 이미지 3개 중 1개 BlackBerry PlayBook Front Panel Replacement, Unclip Mid-Frame: 18 단계, 이미지 3개 중 2개 BlackBerry PlayBook Front Panel Replacement, Unclip Mid-Frame: 18 단계, 이미지 3개 중 3개
      • Unclip all attachments along the sides of the tablet.
      • Two large clips on the top of the device.
      • Four medium clips on the bottom of the device.
      • One small clip on the side of the device, near the headphone jack.
      • This last clip is particularly difficult and might require a sharper tool to remove.
      댓글 쓰기
    5. BlackBerry PlayBook Front Panel Replacement, Lift Mid-Frame: 19 단계, 이미지 1개 중 1개
      • Gently lift the metal mid-frame away from the front panel.
      • A connector runs through a hole in the mid-frame under the area where the motherboard used to rest. While lifting, ensure that this connector is properly fed through the hole.
      댓글 쓰기
    6. BlackBerry PlayBook Front Panel Replacement, Unscrew Display: 20 단계, 이미지 1개 중 1개
      • Remove the one remaining Phillips screw holding the display in place.
      댓글 쓰기
    7. BlackBerry PlayBook Front Panel Replacement, Remove Display: 21 단계, 이미지 2개 중 1개 BlackBerry PlayBook Front Panel Replacement, Remove Display: 21 단계, 이미지 2개 중 2개
      • Gently lift the display out of place.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 7명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Keyon Keshtgar
회원 가입일: 10/11/14
433 평판
안내서 1개를 작성함
Cal Poly, Team 14-27, Maness Fall 2014 Cal Poly, Team 14-27, Maness Fall 2014 회원
CPSU-MANESS-F14S14G27
4 회원들
안내서 12개를 작성함
2가이드 댓글
Where can I get a blackberry playbook screen am in Kenya
Emily Opondo - 답글 공유
Did you get the screen? I need it too.
Koyo Iain - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 30
전체 시간: 5,915
